Topic: Sound sensor use (Read 2228 times) previous topic - next topic
a760109
hi
Is it possible for an Arduino use sound sensor( http://www.emartee.com/product/41850/Arduino%20Sound%20Sensor )
By serial point makes the signal into music files (map ,wav...)
or
By serial point makes the signal into Decibel
Thank You.
AWOL
1) The Arduino has a relatively low analogue sample rate of just under 10kHz, implying an audio bandwith of about 5kHz, or a little better than telephony standards.
However, the Arduino has very little memory (so far as audio samples are concerned) and writing to things like SD cards is relatively slow.
2) Possibly, if you have a calibrated device.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
a760109
thank,by the way
if Arduino + sound sensor can get serial port information to save on the computer.
how do i get  music files or Decibel by serial port.
change to music files,use ADC(Analog-to-Digital Converter) ??
can give me some direction...thank.
change to Decibel , how doing ??
thank very much.
Grumpy_Mike
It is not at all clear from that web site if the sound sensor will produce an audio waveform or is what is known as an envelope detector. The English on that site is very bad. If it is an envelope detector then you can't get music through it anyway.
