Topic: Problems communicating with processing (Read 2253 times) previous topic - next topic
samwhiteUK
Hi guys,
My problem is as follows -
I am following an Arduino tutorial with processing and TouchOSC on my iPhone to control an RGB LED. So far, I have the TouchOSC interface created and it can control the Processing sketch (3 simple sliders). However, I run into the following problem when trying to add the Arduino to the equation.
Here is the code for the Procsessing sketch:
Code: [Select]
import cc.arduino.*;
import processing.serial.*;
import oscP5.*;
import netP5.*;
Arduino arduino;
OscP5 oscP5;
float redAmount = 0.0f;
float greenAmount = 0.0f;
float blueAmount = 0.0f;
void setup(){
  size(320, 480);
  background(0);
  oscP5 = new OscP5(this, 8000);
  [color=red]arduino = new Arduino(this, Arduino.list()[0],57600);[/color]
void draw(){
  background(redAmount, greenAmount, blueAmount);
  fill(0);
  //red rect
  stroke(255,0,0);
  rect(34,39,67,255);
  fill(50,40,40);
  rect(34,39+255,67,-redAmount);
  //green rect
  fill(0);
  stroke(0,255,0);
  rect(124,39,67,255);
fill(40,50,40);
  rect(124,39+255,67,-greenAmount);
  //blue rect
  fill(0);
  stroke(0,0,255);
  rect(216,39,67,255);
  fill(40,40,50);
  rect(216,39+255,67,-blueAmount);
  //write to arduino
  arduino.analogWrite(11, int(redAmount));
  arduino.analogWrite(10, int(greenAmount));
  arduino.analogWrite(9, int(blueAmount));
void oscEvent(OscMessage theOscMessage){
  String addr = theOscMessage.addrPattern();
  float val = theOscMessage.get(0).floatValue();
  if(addr.equals("/1/red")){ redAmount = val;}
  if(addr.equals("/1/green")){ greenAmount = val;}
  if(addr.equals("/1/blue")){ blueAmount = val;}
The issue occurs at the red line.
The error is as follows:
Exception in thread "Animation Thread" java.lang.ArrayIndexOutOfBoundsException: 0
    at Colour_Mixer.setup(Colour_Mixer.java:45)
    at processing.core.PApplet.handleDraw(Unknown Source)
    at processing.core.PApplet.run(Unknown Source)
    at java.lang.Thread.run(Thread.java:662)
I have read that I should perform a println(Arduino.list()), but where can I read the output of this command?
I am running Ubuntu Linux 10.10 Maverick Meerkat 64 bit, Processing 1.5.1, and I have tried uploading both the Standard Firmata and the Standard Firmata For Uno sketches to the Arduino.
Thanks in advance,
Sam
johnmchilton
The output of the println should appear in the Processing console below the editor.
samwhiteUK
Many thanks - I was not seeing this due to a java version mismatch. All is well now.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
