Topic: Replacement FTDI IC (ATMEGA8U2) (Read 2380 times) previous topic - next topic
emielzij
I would like to replace the FTDI IC the ATMEGA8U2.
I am almost sure that that is why my arduino isn't reconised by my computer.
I already resolderd the ic but that hasen't helped. So I want to replace it by a new one.
Is is possible to just buy the ATMEGA8U2, or need it to be programed?
cmiyc
The ATmega8u2 is not a FTDI.  "FTDI" is a brand of serial to USB chips. The ATmega8u2 is a general purpose microcontroller that is programmed to work as a serial to USB device.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
oric_dan
Quote
You must be very good to re-solder such a small smt pitch chip. Did you ever have it
working correctly in the first place? There are sometimes installation problems with the
drivers. I'm not sure how someone can fry only that chip on a board.
retrolefty
Quote
Yes, very easy to do in the older arduino boards that used a FTDI chip. The shield 3.3v pin was supplied by the FTDI chip but was limited to 50ma output current or less and if one attempted to draw more then that or accidental shorted the 3.3v pin to ground the FTDI could be destroyed without damaging anything else on the board.
Lefty
oric_dan
Quote
Ah so. What about on the newer boards that have their own 3.3V v.reg? How do you fry
just the 8U2 or 16U2 chip?
retrolefty
Quote
Not sure there is a clear cut and repeatable method of just destroying the 8U2 or 16U2 chips without also subjecting other components to damage. Perhaps if one placed high voltage onto the USB D+ and/or D- pins?
Lefty
oric_dan
Quote
That doesn't seem very likely, unless the PC USB port was putting out high voltage.
How often does a PC USB port do that? They're probably fairly bulletproof, given the
hazards a PC faces day to day. Otherwise, OP would have to be sticking live wires into
the USB connector. Also, the UNO boards have some protection on the D+,D- pins.
I'd bet OP has some "other" problem, and has possibly wrecked the bd in the meantime
by resoldering the USB chip. I'd not want to try an resolder such a tiny pitch part.
