Topic: I2C run off of resister regulated supply ok? (Read 1 time) previous topic - next topic
SouthernAtHeart
http://www.sparkfun.com/products/9418
This is powered off of 3.3 v, but in my application, daisy chained with 2 other i2c devices it would be inconvenient to get the 3.3 pin off the UNO.  Can I just feed this with the 5 v supply all my other I2C devices are fed with and put a resister in to drop the voltage? What size would work?   It only uses 10 uA. And runs at 1.4 - 3.6 v.  If I aimed at 2 to be safe?
Thanks.
johnmchilton
#1
Jun 16, 2011, 07:09 am Last Edit: Jun 16, 2011, 07:24 am by johnmchilton Reason: 1
I'm no electrical engineer, but I know one. What you need is a voltage divider. It's two resistors. I watched him calculate the resistor values by hand one time, so it shouldn't be too hard. I'll let you do the Googling.
BTW, interfacing w/software on the computer ??
SouthernAtHeart
I see where a voltage divider would work to connect the 3.3 v sensor pin to the 5 volt Uno, but what about actually powering the sensor... ?
johnwasser
To make everything reliable you should use a voltage regulator to provide 3.3v for your I2C device.
Things are going to get difficult when you try to connect SCL and SDA from your 3.6v MAX chip to the 5v Arduino.  The SCK shouldn't be too bad since it is always from the Arduino to the chip and a voltage divider can to drop the signal voltage.  The problem is the SDA pin which is bi-directional.  You can't just throw in a voltage divider because then the 3.3v chip might not be able to drive the Arduino input.
Good luck.
SouthernAtHeart
Thanks, i'll switch to a different sensor...
Grumpy_Mike
You can convert the bi-directional data signal's voltage level with two transistors or FETs. Try searching for level shifting schematics.
But you can't power anything off a resistor or voltage regulator.
johnmchilton
Wait, wait, wait. Just read the datasheet.
3.3v will be above the threshold for logic high, and completely out of the "gray area".
Section 29.1.9
http://www.atmel.com/dyn/resources/prod_documents/doc8025.pdf
johnmchilton
Whoops, that's the 168. I'll check the 328 next...
Grumpy_Mike
Yes but the 3v3 device's input will be being pulled up to 5v and that will kill it.
johnmchilton
So why not run SDA and SCL both at 3.3v?
Grumpy_Mike
You need to hack into the library and not enable the internal pull up resistors.
johnmchilton
Can't you just pinMode them as INPUTs and write LOW?
http://www.arduino.cc/en/Reference/DigitalWrite
Grumpy_Mike
Yes if you are not using the I2C library buti suspect you are.
