Topic: I2C read problems (Read 13714 times) previous topic - next topic
herctrap
#45
Jul 30, 2011, 12:12 am Last Edit: Jul 30, 2011, 12:21 am by herctrap Reason: 1
it gives me an error if i used your code in the compliler
is it gone work if i change the
#define BUFFER_LENGTH 32
from the wire.h?
and the TWI_BUFFER_LENGTH 32
from twi.h
nickgammon
What error? What code? I was just pointing out the 5 places it is used.
from the wire.h?
from twi.h
Yes, that was what I was suggesting. Although "work" may be a loose term. If you run out of memory it won't work.  I don't know if there is some hardware limit, I don't think there is.
You will of course need to change both ends, the sending end and the receiving end.
herctrap
#include <Wire.h>
#define I2C_Address 2
#define UartBaudRate 57600
int Position;
byte OS4000Data [128];
char command;
 Serial.begin(UartBaudRate);
 Wire.begin(I2C_Address);
 Wire.onRequest(requestEvent);
 Wire.onReceive(ReceiveCommand);
 if(command == 'C')
   Capture_OS4000();
   command = 'N';
void ReceiveCommand(int howMany)
 while(!Wire.available());
 command = Wire.receive();
void requestEvent()
   Wire.send ("kffkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkdd");
   //Wire.send (OS4000Data, 127);
void  Capture_OS4000()
 Serial.flush();
 while ( Serial.read () != '$' );
 Serial.flush();
 while( Serial.available() < 127 );
 OS4000Data[Position] = Serial.read();
#include <Wire.h>
#define requestdelay 25
void setup(){
 Wire.begin();
void loop(){
 Wire.beginTransmission(2);
 Wire.send('C');
 Wire.endTransmission();
delay(200);
 Wire.requestFrom(2,40);
 for ( int i=0; i<40; i++ ) Serial.print(Wire.receive());
 Serial.println();
not working with the above code
i am reading kffkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
and not         kffkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkdd
nickgammon
Well I can't reproduce your problem. I changed the two defines I mentioned, and then amended your code slightly. This is the slave:
#include <Wire.h>
char command;
char buf [131] = "";
  for (int i = 0; i < 13; i++)
    strcat (buf, "0123456789");
  if(command == 'C')
    command = 'N';
void requestEvent()
    Wire.send ((uint8_t*) buf, 128);
And this is the master:
#include <Wire.h>
#define AMOUNT 128
void setup(){
  Wire.begin();
void loop(){
  Wire.beginTransmission(I2C_Address);
  Wire.send('C');
  delay(200);
  Wire.requestFrom(I2C_Address, AMOUNT);
  if (Wire.available () == AMOUNT)
    for ( int i=0; i<AMOUNT; i++ )
      Serial.print(Wire.receive(), BYTE);
    Serial.println (Wire.available (), DEC);
  Serial.println();
And this is the debug output:
01234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567
As you can see, 128 bytes of the correct data.
From your code:
void loop(){
  Wire.send('C');
delay(200);
  Serial.println();
The second Wire.beginTransmission is not correct - you don't do another beginTransmission before a requestFrom.
nickgammon
Make sure you upload both sender and receiver. The slave does not send the extra data if you try to send more than the maximum in the define.
herctrap
thanks it worked
for some reason the buffer size into the wire.h was 32 and not 128
herctrap
hallo again
i also tried to change the values in anrduino 1.0
but it didn't worked
nickgammon
What files did you change exactly?
herctrap
wire.h and twi.h into the library folder
nickgammon
Can you be a bit more specific? What didn't work? Under version 1.0 you would have had to change other things too.
herctrap
The master
asks for data
void Read_Data()
 Wire.write('H');
 delay(200);
 Wire.requestFrom(2,127);
 for ( int i=0; i<128; i++ ) Serial.write(Wire.read());
 Serial.println("");
and on the slave
 command = Wire.read();
 if (command == 'H')
   Capture_OS4000();
   command = 'N';
 //Serial.println("mpika capture"); // debug
 //Serial.flush();
 //Serial.flush();
 OS4000Data[0] = '$';
 for(Position=1; Position<128; Position++){
   buf = Serial.read();
   if ( buf == '*' ) EOL = Position + 2;
   if ( Position <= EOL ) OS4000Data[Position] = buf;
   else OS4000Data[Position] = B0;
void requestEvent()
 //Wire.write (OS4000Data, 127);
  Wire.write ("AbcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789000987654321");
but i am receiving
AbcdefghijklmnopqrstuvwxyzABCDEFÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
thanks
nickgammon
In my copy they are in the Wire and Wire/utility folder.
herctrap
herctrap
if you make it work can you send me the files please
because I edit it with wordpad
thanks a lot
nickgammon
I'm not going to make it work and send it to you. Edit two files and change 2 numbers. At least show here what changes you made.
