Topic: I2C read problems (Read 13699 times) previous topic - next topic
herctrap
as before i changed the
#define BUFFER_LENGTH 128
into wire.h
and
  #define TWI_BUFFER_LENGTH 128
into twi.h
from 32 to 128
nickgammon
I changed both of those, and ran this sketch:
#include <Wire.h>
void setup ()
  Wire.begin ();
void loop ()
  Wire.beginTransmission (25);
  Wire.write ("AbcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789000987654321");
  Wire.endTransmission ();
  delay (1000);
All the bytes were sent (I could see with the logic analyzer). I also had to recompile and re-upload the receiving Arduino as well.
herctrap
herctrap
also the slave is a custom board
and i am using Arduino Pro at 8Mhz because Atmega328 on a breadboard isnt working any more on Arduino 1.0
herctrap
herctrap
#include <Wire.h>
void setup ()
  Wire.begin ();
void loop ()
  delay (1000);
on the 8Mhz board
herctrap
also i get the same output from an atmega1280 at 16Mhz
herctrap
and from an arduino uno board
nickgammon
These pictures don't show much. They show about one byte, and you are trying to send around 72.
herctrap
i dont have a logic analyzer yet
can you please send me your files to test
thanks a lot
herctrap
i made it
i re-downloded the arduino 1.0
unzip it in dekstop
change the files in dekstop
and then replace it in Programm files
thanks a lot
