Topic: XBee Series1 XB24 and XB24-DM firmware does not work ! (Read 2479 times) previous topic - next topic
aadeesh
Hello,
My aim is to have 2 transmitters sending serial data to receiver connected to PC via Xbee Explorer board.
I am using XBee "Series 1" modules.
My setup is as follows:
Arduino (AD) powered using USB and XBee (XB) attached to self-made shield (powered using AD_3V3).
I am using NewSoftSerial library for communication at 9600 baud rate to avoid interference with FTDI.
So, i have attached the XB_DIN pin to AD3 pin.
My XB's configuration tested till now:
(Just point to point to test)
1)
XBeeTX: DL-1, MY-2 (Arduino)
XBeeRX: DL-2, MY-1 (PC)
(PAN-3332, BD-9600)
2)
XBeeU: DL-1, MY-2 (Arduino)
XBeeD: DL-2, MY-1, CE-1 (PC)
(PAN-3332, BD-9600)
Both the above configuration are "not working".
In order to confirm whether my hardware is working or not, I tested it with my "Series 2" modules lying around.
And the setup works with them.
Then, i changed the firmware to XB24-DM (XBee Digimesh) and configured them as follows:
Receiver:
PAN-1234
SH-13A200
SL-4064036E
DH-0
DL-FFFF
Transmitter
PAN-1234
DH-13A200
DL-4064036E
And surprisingly it does not work too.
Please help me to debug this.
Regards-
Aadeesh
Code:
Quote
#include <NewSoftSerial.h>
NewSoftSerial softSerial(2, 3);
unsigned int prevValue = 0;
unsigned int newValue = 0;
  softSerial.begin(9600);
  pinMode(13, OUTPUT);
  newValue = analogRead(0);  // Read Potentiometer A (0 to 1023)
  //softSerial.println("Working !");
  // Send if potentiometer values is changed
  // If loops are to set the tolerance limits of the digital potentiometer values
  if (newValue != prevValue)
    if ((newValue - 1) != prevValue)
      if((newValue + 1) != prevValue)
        if((newValue - 2) != prevValue)
          if((newValue + 2) != prevValue)
            if((newValue - 3) != prevValue)
              if((newValue + 3) != prevValue)
                digitalWrite(13,HIGH);
                softSerial.print("NODEA ");
                softSerial.println(newValue);
                prevValue = newValue;
                digitalWrite(13,LOW);
  delay(20);
References:
http://www.wsncloud-murdoch.org/wiki/index.php/Wireless_Communication#Wireless_Mesh_Network
http://www.kobakant.at/DIY/?p=270
waqasaps
digimesh supports xbee 802.15.4.
DigiMesh can be used on two XBee modules: XBee 802.15.4 and XBee 900MHz. There are some differences between both modules as the frequency used (2.4GHz vs 900MHz) or the power transmission.
