Loading...
Pages: [1]   Go Down
Author Topic: How about an onboard DAC  (Read 526 times)
Offline Offline
Newbie
View Profile
It sure would be nice to have a DAC to go along with the ADC.  Also some software keywords would be nice to help out with that.
That's my twenty two cents.(Inflation)
Thankyou
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
The problem with an on board D/A is similar to that of the A/D in that these use analogue signals in a digital environment. This makes the chip more expensive to make especially as the resolution goes up. There are chips with a built in D/A just not many of them and none of them are and arduino.
Logged
Offline Offline
Newbie
View Profile
WWW
if you do a bit of hacking on the internal timers you might be able to get better than ~500hz PWM.  Just a thought.  The ~500hz is compatible with servos which is probably why it was done that way.  Check out the 'analogWrite' code (and related code) for more info.
Also you can get external digital sound processor shields, which are better suited to audio output.  Then use the arduino to control the higher level audio processor.
There aren't many analog applications (other than audio) that require 'faster than 1msec' PWM analog output.  But if they do you can probably hack up a good solution.  Dampened feedback and predictive 'net error' signals, etc.
Logged
Offline Offline
Brattain Member
View Profile
WWW
No need to hack it's been done. Just one of several possible links:-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1152547089
Logged
Pages: [1]   Go Up
Print
Jump to:
