Loading...
Pages: [1]   Go Down
Author Topic: converting data in an array after a wireless transmission  (Read 473 times)
Offline Offline
Newbie
View Profile
HI, I'm using a nRF24L01 to send a value between to Arduino's. The problem is on the receiver side the data is in an array format. I want to have the value stored as a regular int. How do you convert an array like this to a regular int?
I am new to this so.. would there be a way just to transmit the INT not in an array format?
This is the receiver
Code:
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
char rec[16];
int data[16];
int numbers[3];
void setup(){
  pinMode(4, OUTPUT);
    Mirf.spi = &MirfHardwareSpi;
    Mirf.init();
   Mirf.setRADDR((byte *)"serv1");
    Mirf.payload = 16;
   char data[Mirf.payload];
  Mirf.config();
void loop(){
   data[Mirf.payload];
  if(!Mirf.isSending() && Mirf.dataReady()){
    while(!Mirf.dataReady()){
    Mirf.getData((byte *) &rec);
      Serial.print(rec[0]);
      Serial.print(rec[1]);
      Serial.println(rec[2]);
Here is the transmitter
Code:
#include <SPI.h>
#include <Mirf.h>
int rate = 0;
char buffer[16];
char data[16];
void setup(){
  Mirf.init();
  Mirf.setRADDR((byte *)"clie1");
  Mirf.payload = 16;
  Mirf.config();
void loop(){
rate = rate + 1;
    Mirf.setTADDR((byte *)"serv1");
    data[Mirf.payload];
sprintf(buffer,"%1d",rate);
    Mirf.send((byte *) &buffer);
    while(Mirf.isSending()){
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Lose the array.
Code:
int rate;
Mirf.payload = sizeof(rate);
Mirf.send(&rate);
Mirf.getData(&rate);
Also please consider using the "Auto-Format" command on code before posting to make it easier for folks to read.
« Last Edit: June 16, 2011, 09:36:20 pm by maniacbug » Logged
Offline Offline
Newbie
View Profile
Thanks, i tried this. I get an error compiling when I try to put an int directly into the Mirf.send function. I found another post on converting array into int. Its ugly but it works.  I did not realize there was a auto format tool. I will use it from now on. Thanks for the pointer.
Code:
char buffer[3];
  buffer[0] = rec[0];
  buffer[1] = rec[1];
  buffer[3] = '\0';
  int  n;
  n = atoi(buffer);
  Serial.println(n);
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Aargh, Mirf kills me.  I suppose it prefers this...
Code:
Mirf.send((byte*)&rate);
Logged
Pages: [1]   Go Up
Print
Jump to:
