Topic: Frequency Counter Library (Read 114336 times) previous topic - next topic
Stoni
Sorry, I forgot to mention it ... you are right, I am using this library: http://interface.khm.de/index.php/lab/experiments/arduino-frequency-counter-library/. And I am using a Arduino Duemilanove.
The frequency I'd like to measure are under 10kHz. Do you have an example code in which one or more timers are disabled? I tried to look for an other library, but all of them are using the 3 timers ... so I would be really glad if you can help me out!
thanks in advance.
dc42
1. What will be the approximate frequency, and how accurately do you need to measure it?
2. Will the input be a 5V square wave, or would you like to use the built-in analog comparator to allow much smaller input signals?
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
Stoni
The frequency will be between 85 and 255Hz.
I am using a pulse Generator which gives sqare waves with a maximum of 5V.
robtillaart
Code: [Select]
then using an interrupt might be the easiest way - check attachInterrupt example
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
dc42
Try this:
Code: [Select]
// Frequency counter sketch, for measuring frequencies low enough to execute an interrupt for each cycle
// Connect the frequency source to the INT0 pin (digital pin 2 on an Arduino Uno)
volatile unsigned long firstPulseTime;
volatile unsigned long lastPulseTime;
volatile unsigned long numPulses;
void isr()
  unsigned long now = micros();
  if (numPulses == 0)
    firstPulseTime = now;
    lastPulseTime = now;
  ++numPulses;
  Serial.begin(19200);
// Measure the frequency over the specified sample time in milliseconds, returning the frequency in Hz
unsigned int readFrequency(unsigned int sampleTime)
  numPulses = 0;                      // prime the system to start a new reading
  attachInterrupt(0, isr, RISING);    // enable the interrupt
  delay(sampleTime);
  detachInterrupt(0);
  return (numPulses < 2) ? 0 : (1000000UL * (numPulses - 1))/(lastPulseTime - firstPulseTime);
  unsigned int freq = readFrequency(1000);
  Serial.println(freq);
dc42
#35
Oct 18, 2013, 10:50 am Last Edit: Oct 18, 2013, 11:07 am by dc42 Reason: 1
Here is an improved version of the frequency counter sketch. There were a couple of problems with the previous version:
- when you attach the interrupt, you can get an immediate interrupt if this input is already high. This resulted in some jitter in the frequency reading. So I now ignore the first interrupt.
- if the pulse count (i.e. frequency multiplied by the sample time in seconds) was greater than about 4000 then the calculation would overflow. So I have changed it to use floating point calculation instead. This also give a more precise result when the number of cycles counted is low.
Code: [Select]
void isr()
 if (numPulses == 1)
 ++numPulses;
 Serial.begin(19200);    // this is here so that we can print the result
 pinMode(3, OUTPUT);     // put a PWM signal on pin 3, then we can connect pin 3 to pin 2 to test the counter
 analogWrite(3, 128);
float readFrequency(unsigned int sampleTime)
 delay(sampleTime);
 detachInterrupt(0);
 return (numPulses < 3) ? 0 : (1000000.0 * (float)(numPulses - 2))/(float)(lastPulseTime - firstPulseTime);
 float freq = readFrequency(1000);
robtillaart
Very good sample DC42,
another argument to use float division is that integer division truncates.
(you just beat me :)
Rob Tillaart
Stoni
Oh great! Thanks alot!!
This Frequency counter works really really good for me! Now I can move on  :) ...
dc42
One thing I found while testing this is that the PWM frequency on pin 3 is not 488.28Hz as documented at http://playground.arduino.cc/Main/TimerPWMCheatsheet, it is in fact 490.20Hz. This makes sense, since timers 1 and 2 on the Uno are configured in phase-correct PWM mode, in which the timer counts from 0 to 255 and then back again, giving 510 steps not 512. The PWM frequency on pin 5 (controlled by timer 0 in fast PWM mode) is 976.57Hz as documented.
venu5056
i have a small question for u..that is it possible to measure the freq of the sine wave using arduino...
dc42
To measure the frequency of a sine wave, you can either convert it to something resembling a square wave using additional hardware, or you can use the built-in analog comparator. I have found that the analog comparator is extremely sensitive and you need good wiring layout to avoid getting spurious counts due to noise.
dariq88
#41
Dec 17, 2013, 09:39 pm Last Edit: Dec 17, 2013, 09:50 pm by dariq88 Reason: 1
hello!
I tried to modify the library freqcounter for arduino leonardo, but does not start, can you give me a hand to find errors?
Thank
Ps sorry for my English
Code: [Select]
#include <FreqCounter.h>
unsigned long FreqCounter::f_freq;
volatile unsigned char FreqCounter::f_ready;
volatile unsigned char FreqCounter::f_mlt;
volatile unsigned int FreqCounter::f_tics;
volatile unsigned int FreqCounter::f_period;
volatile unsigned int FreqCounter::f_comp;
void FreqCounter::start(int ms) {
#if defined (__AVR_ATmega32U4__)//(__AVR_ATmega168__) || defined (__AVR_ATmega48__) || defined (__AVR_ATmega88__) || defined (__AVR_ATmega328P__) || (__AVR_ATmega1280__)
   TIMSK0 &=~(1<<TOIE0);       // disable Timer0  //disable  millis and delay
   delayMicroseconds(50);      // wait if any ints are pending
   f_period=ms;
   if (f_comp ==0) f_comp=1;  // 0 is not allowed in del us
   // hardware counter setup ( refer atmega32u4)
   TCCR1A=0;                  // reset timer/counter1 control register A
   TCCR1B=0;                 // reset timer/counter1 control register A
   TCNT1=0;             // counter value = 0
TCNT3=0;
   // set timer/counter1 hardware as counter , counts events on pin T1 ( arduino pin 12)
   // normal mode, wgm10 .. wgm13 = 0
   TCCR1B |=  (1<<CS10) ;//CLOCK ESTERNO su fronte di salita
   TCCR1B |=  (1<<CS11) ;
   TCCR1B |=  (1<<CS12) ;
   // timer3 setup / usato per la generazione del tempo di lettura
   TCCR3A=0;
   TCCR3B=0;
   // timer3 presaler set to 64 / timer3 clock = 16Mhz / 64 = 250.000 Hz
   TCCR3B &= ~(1<<CS30) ;
   TCCR3B |=  (1<<CS31) ;
   TCCR3B |=  (1<<CS32) ;
   //setta il timer3 to CTC(Clear Timer on Compare)  Mode with OCR3A is top counter value (arrivato a OCR3A si resetta)
   TCCR3A &= ~(1<<WGM30) ;
   TCCR3A &= ~(1<<WGM31) ;
   TCCR3A |=  (1<<WGM32) ;
TCCR3A &= ~(1<<WGM33) ;
   OCR3A = 249;                // CTC divider by 250
   f_ready=0;                  // reset period measure flag
   f_tics=0;                   // reset interrupt counter
   GTCCR = (1<<PSRASY);        // reset presacler counting (perchè resettarlo?)
   TCNT3=0;                    // timer3=0
   TCNT1=0;                    // Counter1 = 0
   TIMSK3 |=(1<<OCIE3A);       // enable Timer3 Interrupt (interrupt di Timer/Counter3 Compare Match A)
                               // External clock source on T1 pin. Clock on rising edge.
   TCCR1B |= (1<<CS12) | (1<<CS11) | (1<<CS10);        //   start counting now
   #endif
//  Timer3 Interrupt Service is invoked by hardware Timer3 every 1ms = 1000 Hz
//  16Mhz/64/250 = 1000 Hz
//  here the gatetime generation for freq. measurement takes place:
ISR(TIMER3_COMPA_vect) {
// multiple 2ms = gate time = 100 ms
if (FreqCounter::f_tics >= FreqCounter::f_period) {
                            // end of gate time, measurement ready
  // GateCalibration Value, set to zero error with reference frequency counter
   //  delayMicroseconds(FreqCounter::f_comp); // 0.01=1/ 0.1=12 / 1=120 sec
   TCCR1B = TCCR1B & ~7;   // Gate Off  / Counter T1 stopped
   TIMSK3 &= ~(1<<OCIE3A);     // disable Timer3 Interrupt(timer del gate)
   TIMSK0 |=(1<<TOIE0);     // enable Timer0 again // millis and delay
   FreqCounter::f_ready=1;             // set global flag for end count period
                                       // calculate now frequeny value
   FreqCounter::f_freq=0x10000 * FreqCounter::f_mlt;  // mult #overflows by 65636
   FreqCounter::f_freq += TCNT1;       // add counter1 value
   FreqCounter::f_mlt=0;
   FreqCounter::f_tics++;             // count number of interrupt events
   if (TIFR1 & 1) {           // if Timer/Counter 1 overflow flag
   FreqCounter::f_mlt++;               // count number of Counter1 overflows
   TIFR1 =(1<<TOV1);         // clear Timer/Counter 1 overflow flag
   // PORTB = PORTB ^ 32;   // int activity test
dariq88
Now the library also works for leonardo
Code: [Select]
#include "FreqCounter.h"
volatile unsigned long FreqCounter::f_freq;
    f_period=ms/2;
    // set timer/counter1 hardware as counter , counts events on pin T1 ( arduino leonardo pin 12)
    // timer0 setup / usato per la generazione del tempo di lettura
    TCCR0A=0;
    TCCR0B=0;
    // timer3 presaler set to 256 / timer3 clock = 16Mhz / 256 = 62.500 Hz
    TCCR0B = (1<<CS02);
    //setta il timer0 to CTC(Clear Timer on Compare)  Mode with OCR3A is top counter value (arrivato a OCR3A si resetta)
    TCCR0A = (1<<WGM01);  // CTC mode, normal (no Output compare)
    GTCCR |= (1<<PSRASY);  // reset prescaler (undocumented bit in mega32u4?)
    TCCR0B = (1<<CS02);  // timer0 on clk/256 == 16MHZ / 256 = 62500hz..
    OCR0A = 124;  // 125 counts of 62500 Hz before an output compare interrupt...
    TCNT1 = 0;
    TCNT0 = 0;
    TIMSK0 = (1<<OCIE0A);
    #endif
//  16Mhz/256/124 = 500 Hz (corretto con il dimezzamento del period)
ISR(TIMER0_COMPA_vect) {
    TIMSK0 &= ~(1<<OCIE0A);    // disable Timer3 Interrupt(timer del gate)
    //TIMSK0 |=(1<<TOIE0);      // enable Timer0 again // millis and delay
robtillaart
Thanks for fixing Leonardo support,
mismatch between code and comment :)
Rob Tillaart
dariq88
Ops,probably there are others mismatch, sorry :smiley-yell:
