Topic: Frequency Counter Library (Read 125874 times) previous topic - next topic
idkwat2namme
I am new to the site, but I have been programming micros and Arduino for a little time now. I like the code and it works great. I am using it with a variable reluctance sensor and some support circuitry. I wanted to use you code and take the frequency value and output an analog signal in a ratio of the frequency. For example I take the frq from the example and ledBrightness=map(frq,0,fastestFrequency,0,255) but i cannot seem to get a signal out with the analogWrite() command. Does this library mess with the timer that controls the PWM timing of the analogWrite() command?
matinzk
Been using the Frequency Measurement Library, it's great. Been using it to measure the speed and RPM on my car. Is there a way of measuring 0 frequency to show 0 speed or 0 RPM at all?
Thanks.
idkwat2namme
Thanks.
Just as a heads up, if you are getting your signal from a hall effect sensor you should be able to read zero speed, but from what I have been looking up, most speed sensors are a much cheaper variable reluctance sensor. As I understand it, variable reluctance (VR) sensors do not do well at slow speeds. This code and my VR sensor off of a Borg-Warner T5, for a S-10, cannot go down to 0 rpm. I can only get to 10s or rpm. Hall effect sensor can take true zero speed measurements. Good luck.
matinzk
I am using this:
http://interface.khm.de/index.php/lab/experiments/frequency-measurement-library/
Are we talking about the same library? Is the above library in the link able to detect zero RPM and speed?
This is the hall effect sensor we use:  http://www.digital-speedos.co.uk/hall-effect-speed-sensor-for-drift-gauges-non-magnetic-382-p.asp
smeezekitty
Have you considered using a light based counter? Shine an IR light at whatever is spinning and fix piece of something shiny to it. Then point an IR detector at it which should detect rotation.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
matinzk
How can I do this with a car? Especially the engine rpm?
smeezekitty
Maybe you can fix something shiny or use shiny paint on one of the main belts?
Resistors for LEDS!
Constantin
Please do not paint belts. The paint may damage the belt (thanks to the enclosed / entrained solvents) and lead to premature cracking. Not only are modern belts very expensive to replace, losing one will usually leave you stranded. Not the best way to impress the missus.
Instead use a hall-effect or optical rig on a sprocket or similar device that does not need physical modification.
smeezekitty
Honestly this is not my place to expertise but it would seem there is certain types of paints that would not be a problem.
Last time I looked, the belts were not all that expensive. But losing one can indeed leave you stranded but alas this is a risk with any type of engine modification.
Resistors for LEDS!
Constantin
SmeezeKitty, do as you wish.
All I can tell you is that I had to replace every rubber hose on a diesel engine because some lugnut sprayed them with the same 'Perkins blue' as the rest of the engine. And to do that, we got to lift the engine out of the boat, drain it of all fluids, etc. Not the fastest fix.
Every hose had cracked thanks to this painting treatment. Given how important belts are, I wouldn't mess with them and pick up the desired signal elsewhere.
boriskourt
I got this to work well on one sensor, using my Arduino UNO.
But I have not been able to get it to work at all on a Leonardo. [ Serial doesn't even print the 'Frequency Library' line at the start] Have there been major changes to serial for Leonardo?
Another question is, how would I be able to expand this to multiple sensors without using multiple Arduinos?
iw4blg
Hello to everybody, first of all I'm not an expert altought I have succeed so far with some small Arduino based project.
I'm now trying to develop a radioastronomic receiver (radiometer) controlled by Arduino.
Now the topic:
- I have an Arduino Uno rev.2 with an Ethernet shield with microSD slot (both not yet used, but useful later on)
- In order to control the receiver I have to program 2 different PWM on 2 different pins
- for what I read on the web pages, I can use the instruction analog.write(pin,pwm) on the pins 3,5,6,9,10,11 if not already used by other devices
- the pin 5 (T1) is used to read the OL frequency of the receiver by means of the library FreqCounter.h herewith discussed..
- pin 3 seems to be used by the Eth shield as well as the pins 0,1,2,4,10,14,15
- thus, "fre to be used" for my purpose, remain the pins 6,9,11
Unfortunately only the output on the pin 6 works. Pins 9 and 11 always are at low level, no PWM, even with no shield on top of the Arduino Uno.
The board works fine is I do not call the frequency reading routine.
What I'm doing wrong? Waht shall I do to fix the trouble?
On the following a draft of the cose I'm using. Please note it's a very early draft of what I would do, so several variables are defined but not used yet.
Many thanks to all for the help!
Pierluigi
#include <FreqCounter.h>
// OL input on digital pin #5
const short pwm1=9; // pin 9 is 8 MSB PWM
const short pwm2=6; // pin 6 is 8 LSB PWM
long int frq; //frequency read
long int IF=10700000; // first IF of the Rx
const short prescaler=8; // scale factor of the ext. prescaler
const long int fastro1=25610000; // astro1 = 1st frequency
const long int fastro2=13385000; // astro2 = 2nd frequency
long int OLnow; // current OL frequency
long int RXnow; // current RX frequency
long int errore=0; // frequency error
int pwmh; // 8 MSB of PWM
int pwml; // 8 LSB of PWM
float Vastro1=0.2035; // VCO nominal input for fastro1
// float Vastro2=3; // VCO nominale per rx frequenza fastro2
int bitbase1=Vastro1*65535/5; // total PWM bits (res.16) of feed forward VCO a freq. astro1
// int bitbase2=Vastro2*65535/5; // bit di PWM totali (risoluzione 16) del feed forward tensione VCO a freq. astro1
  Serial.begin(9600);                    // connect to the serial port
  Serial.println("Frequency Counter");
  FreqCounter::f_comp= 5;             // Set compensation
  FreqCounter::start(1000);           // Start counting with gatetime of 100ms
  while (FreqCounter::f_ready == 0)   // wait until counter ready
    frq=FreqCounter::f_freq;          // read result
  OLnow= frq*prescaler;  // OL frequency calculation
  RXnow= OLnow-IF;  // RX frequency from IF and OL
  errore= RXnow-fastro1; // tuning freq. errorcalcolo errore di sintonia
  pwmh= bitbase1/256;
  pwml= bitbase1-256*pwmh;
analogWrite(pwm1, pwmh);
analogWrite(pwm2, pwml);
  Serial.print("bitbase1= ");
  Serial.print(bitbase1);
  Serial.print("  pwmh= ");
  Serial.print(pwmh);
  Serial.print("  pwml ");
  Serial.print(pwml);
  Serial.print("  frq= ");
  Serial.print(frq);
  Serial.print("  OLnow= ");
  Serial.print(OLnow);
  Serial.print("  RXnow= ");
  Serial.print(RXnow);
  Serial.print("  Errore= ");
  Serial.println(errore);
  delay(20);
Pierluigi IW4BLG
dc42
How about a variation on the frequency counter lib that takes its input from the analog comparator? This would avoid the need for a preamplifier. You wouldn't be able to count the input directly in counter 2 because AFAIK it can't be clocked from the analog comparator output. However, you could use the analog comparator interrupt to count pulses, and use timer 1 as before to define the gate time.
Stoni
Hey,
first of all, thanks for the great library!
I have a small issue with my LEDs and this library. They are working if I give them the value "HIGH" or "255". But however they are not working with a lower value. I have tested the leds in an other sketch. So they are correctly wired and working fine, also the arduino. It seems to be a problem with the "FreqCounter::start(100);", if I remove it, the lower values are working, but of course the frequency counter not...
has someone an idea? thanks in advance!
dc42
Assuming you mean the frequency counter library at http://interface.khm.de/index.php/lab/experiments/arduino-frequency-counter-library/, it uses timers 1 and 2, and disables timer 0 during the gate time. This means that none of the PWM pins on a Uno will work while you are measuring a frequency.
If the frequency you want to measure is less than about 10kHz, there are other ways of measuring it that take over only one timer, or even no timers at all.
