Topic: Arduino BT and serial repeater (Read 2336 times) previous topic - next topic
marcotrapanese
Hello,
I'm using Arduino BT (ATmega328) as "gateway" between a PC and another board (with ATmega164P). The serial connection between the two boards is @ 9600 baud (tried also lower rates). The arduino code is very simple:
Code: [Select]
#include <NewSoftSerial.h>
int rxPin = 2;
int txPin = 3;
NewSoftSerial mySerial(rxPin, txPin);
 mySerial.begin(9600);
 if (Serial.available()) {
   mySerial.print((char) Serial.read());
 if (mySerial.available()) {
   Serial.print((char) mySerial.read());
First of all, one question: the serial between atmega328 and the BT chip (WT11) is @ 115200. But it seems I can send data over the virtual COM on the pc at any rate. Is it correct?
Now, let's see the problems. When my own board transmits data to arduino, it repeats correctly each byte to the pc.
When is the PC that sends data to arduino, it repeats only first 3 bytes to my own board. Example: if I send abcdefghi, it will repeats only abc. Of course if I send char-by-char there is no problem.
I was thinking about some buffer underrun (with so small strings?) and implemented a circular buffer:
Code: [Select]
#define BUFFER_SIZE  32
#define BUFFER_MASK  (BUFFER_SIZE - 1)
int rxPin = 2;
int txPin = 3;
int head = 0;
int tail = 0;
char buffer[BUFFER_SIZE];
   buffer[head] = Serial.read();
   head = (head + 1) & BUFFER_MASK;
 if (head != tail) {
   mySerial.print(buffer[tail]);
   tail = (tail + 1) & BUFFER_MASK;
But the behavior is the same.
I checked with the oscilloscope: just the first three bytes are transmitted over.
Any hints?
Thanks!
Marco
robtillaart
Could also be something blocking the receiving of the chars.
DOes the string abcdefghi comes in completely?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
marcotrapanese
I'm pretty sure of this. If I repeat the incoming chars on the same serial (between PC and arduino) it works fine, even if I transmit a long file.
robtillaart
Can you tell which device is connected to the hardware serial and which to the NewSoftwareSerial?
Rob Tillaart
marcotrapanese
I'm talking about the Arduino BT, thus the hardware serial is connected to the BT module WT11 on the Arduino board itself.
The software serial is connected to an ATmega164P (with hw uart) on my own board.
