Loading...
Pages: [1]   Go Down
Author Topic: watching pin state change and if stops change turns motor off  (Read 186 times)
Offline Offline
Newbie
View Profile
Hello all, any help would be great.
i am using
int pulsePin = 3;   //motor hall effect input
how can i do a small sketech to check this is changing state and when stops changing state turns a motor off ?
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
so there is some pulsed signal on pin 3?
what is the frequency?
you should go IRQ based as holding state by a polled digitalRead() can miss pulses.
(code not tested)
Code:
#define THRESHOLD 500   // to be configured, now 500 millisec
boolean motorRunning = false;
volatile unsigned long lastTime = 0;
void IRQ()
  lastTime = millis();
  attachInterrupt(1, IRQ, RISING);  // 1 = pin 3
  if (millis() - lastTime > THRESHOLD)
    motorRunning == false;
    // motorStop();
    if (motorRunning == false)
      motorRunning = true;
      // MotorStart();
Note for safety I propose to stop the motor over and over again if there is no pulse. This is just thinking safety.
Rob
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
thanks fast reply.
my pulse is 6 pulses per mm of travel ( an linerar actuator), about 9 mm travel  per sec
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
so ! 54 pulses per second ... faster than every 25 millisecond. => THRESHOLD = 25
give it a try.
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
