Topic: watching pin state change and if stops change turns motor off (Read 785 times) previous topic - next topic
peter1929
Hello all, any help would be great.
i am using
int pulsePin = 3;   //motor hall effect input
how can i do a small sketech to check this is changing state and when stops changing state turns a motor off ?
robtillaart
so there is some pulsed signal on pin 3?
what is the frequency?
you should go IRQ based as holding state by a polled digitalRead() can miss pulses.
(code not tested)
#define THRESHOLD 500   // to be configured, now 500 millisec
boolean motorRunning = false;
volatile unsigned long lastTime = 0;
void IRQ()
  lastTime = millis();
  attachInterrupt(1, IRQ, RISING);  // 1 = pin 3
  if (millis() - lastTime > THRESHOLD)
    motorRunning == false;
    // motorStop();
    if (motorRunning == false)
      motorRunning = true;
      // MotorStart();
Note for safety I propose to stop the motor over and over again if there is no pulse. This is just thinking safety.
Rob
Rob Tillaart
peter1929
thanks fast reply.
my pulse is 6 pulses per mm of travel ( an linerar actuator), about 9 mm travel  per sec
robtillaart
so ! 54 pulses per second ... faster than every 25 millisecond. => THRESHOLD = 25
give it a try.
Rob Tillaart
