Topic: 3 motor laser spirograph thingy (Read 4011 times) previous topic - next topic
E3po
Hello! I am looking for a little guidance on code for a 3 motor laser show.  I have roughed it together and wired it up without the arduino and it is cool!  I would like a little more control over the motors than the jumpiness I get with pots varying the motor rpms.  Since the three motors are powered from the same p/s (robbed from a nokia cell charger), each motor affects the speed of the others.
I have a adafruit motor shield too and am at a loss as to initial setup with the code.
I would also like to consider varying the speed of the motors via ir remote, and have no idea how to implement that either.
Can anyone suggest a sample code or starting point with a pot for each motor or even the ir route?
Thanks
-e
E3po
Also I wanted to mention, I am using a Mega 2560 so there are plenty of available pins not used or obscured by motor shield.
Thanks!!
-e
AWOL
#2
Jun 19, 2011, 08:44 pm Last Edit: Jun 19, 2011, 09:20 pm by AWOL Reason: 1
Quote
A charger provides maybe 500mA - what do the motors draw?
I'd beef-up the supply first.
How are you buffering the motors?
Quote
Code: [Select]
const int N_MOTORS = 3;
const int motorPin [N_MOTORS] = [ 3, 5, 6};
const int analogPin [N_MOTORS] = { 0, 1, 2};
void setup (){}
void loop ()
 for (int i = 0; i < N_MOTORS; ++i) {
   analogWrite (motorPin [i], analogRead (analogPin [i] / 4));
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
E3po
Thanks for the reply!!
The motor shield running sample code allows the motors to run MUCH smoother than just using a breadboard and pots.
I imagine the caps and such on the motorshield is a sufficient buffer.
I am sorry but have a very limited understanding of coding.  I have more familiarity with electronics and hardware than software.  So could you help me understand the code you suggested?
I am trying to learn in a "trial by fire" method.
Do you know from experience if
corresponds to the motorshield outputs for M1, M2, and M3?
I found this info about motor shield.
Digital pin 11: DC Motor #1 / Stepper #1 (activation/speed control)
Digital pin 3: DC Motor #2 / Stepper #1 (activation/speed control)
Digital pin 5: DC Motor #3 / Stepper #2 (activation/speed control)
Digital pin 6: DC Motor #4 / Stepper #2 (activation/speed control)
would then
const int motorPin [N_MOTORS] = [ 11, 3, 5};
make your code work for motor 1, 2, and 3??
Also how would I implement a random speed in lieu of a manual control?
Does that require if statement and/ or a button or state of the three pots?
Thanks so much for teaching me without making me feel like a total noob!
-e
AWOL
Sorry - I missed the bit about using a shield for the buffering (I was concerned you were driving the motors directly from output pins on the Arduino)
Quote
would then
From what you've posted about the shield, yes, I think it should (I don't have a motor shield)
Quote
Start here:
http://arduino.cc/en/Reference/Random
Quote
Your choice.
E3po
I thank you for helping all! I HAVE MADE SOLID PROGRESS.
Quote
    #include <AFMotor.h>
    AF_DCMotor motor1(1);
    AF_DCMotor motor2(2);
    AF_DCMotor motor3(3);
    int potpin1 = 8;
    int potpin2 = 9;
    int potpin3 = 10;  // analog pin used to connect the potentiometer
    int val1;
    int val2;
    int val3;    // variable to read the value from the analog pin
     val1 = analogRead(potpin1);      // reads the value of the potentiometer (value between 0 and 1023)
     val1 = map(val1, 0, 1023, 0, 255);
     motor1.setSpeed(val1);      // sets the motor speed according to the scaled value
     motor1.run(FORWARD);
      delay(15);
     val2 = analogRead(potpin2);      // reads the value of the potentiometer (value between 0 and 1023)
     val2 = map(val2, 0, 1023, 0, 255);
     motor2.setSpeed(val2);      // sets the motor speed according to the scaled value
     motor2.run(FORWARD);
      delay(15);
     val3 = analogRead(potpin3);      // reads the value of the potentiometer (value between 0 and 1023)
     val3 = map(val3, 0, 1023, 0, 255);
     motor3.setSpeed(val3);      // sets the motor speed according to the scaled value
     motor3.run(FORWARD);
       delay(15);
It works.  Now for random control with "snapshot" function...
E3po
Could anyone suggest a way to use a button connected to another pin to enter a random state
or maybe...
if val1, val2, val3  all equal 0
then { motor1.setSpeed(random 0, 255)
motor2.setSpeed(random 0, 255)
motor3.setSpeed(random 0, 255)}
how would I write that into the code?
Am I even close?
Thanks
-e
E3po
I tried to include at the end of the loop
if (val1, val2, val3 = 0);
      motor1.setSpeed(random(0, 255));
      motor2.setSpeed(random(0, 255));
      motor3.setSpeed(random(0, 255));
but then I cannot ever stop all motors.
i also tried to change the if statement to if (val1 = 255, val2 = 255, val3 = 255)
and it is even more unpredictable.
I have the http://arduino.cc/en/Reference/If  and guess I do not understand it fully
Please help.
Thanks
-e
AWOL
#8
Jun 20, 2011, 09:15 pm Last Edit: Jun 20, 2011, 09:28 pm by AWOL Reason: 1
Quote
So many things wrong.
1) lose the semicolon.
2) comparison is "==" not "="
3)You need to combine conditions with logical AND "&&"
Code: [Select]
if (val1 == 0 && val2 == 0 &&  val3 == 0)
Quote
I'd say that's about as hard-and-fast as it is possible to get
E3po
I tried this
     if (val1 == 255 && val2 == 255 && val3 == 255) {
      motor2.setSpeed(random(0, 255));}
so if all were at zero all motors would stop
but now no random actions happen
BTW much thanks for helping me!
-e
AWOL
Quote
I tried this
Define "stop".
E3po
[/quote]
Define "stop".
[/quote]
Sure
I mean to not move, to cease to rotate, "sleep mode"...
I initially thought it would make sense to initiate a random mode for all three motors by looking for a value of zero at each of the three pots.  After a little thought, it makes more sense in this case for it to initiate the random mode if all pots are set to max.
It is almost pointless in this case to have all three motors spinning at max (not very exciting to look at), but having all three motors stop spinning is useful for me.
When the pots are at max resistance the motors should NOT SPIN.  While, as I said before, all three at full on does not need to ever happen for this project.  So I now think having all three values at 255 would be a viable cue to initiate a random mode.
If I could accomplish that, and temporally keep each motor spinning at their random speed while all three pots are at max, that would rock!
It seems that if that works, then moving any of the three away from and then back to max, would generate a new random "scene".
If that makes sense, that is my goal.
Thanks
-e
AWOL
Quote
So why are you setting the speed to some random value and not, say, zero?
E3po
Thanks AWOL!
I can simply turn all three pots to zero and I get "sleep mode" (no rotation for quiet, saving battery life...).  That said I don't need an if statement or anything to initiate 0,0,0.  I can figure that out.  What I am currently trying to figure out is a way to manually select a "scene" of three random speeds for the motors. (possibly one random number for each val1, val2, and val3)
The fact that all three motors/ pots at max is not useful to me right now, just seemed like a way to cue my code to insert random values.
Initially I was thinking the 0,0,0 state would be a good cue but after a little thought 255, 255, 255 is the way to go.
I have learned a lot from your posts so thank you!
Thanks
-e
E3po
So I wanted to share my "progress".  I have at this point 90% functionality but have just one question.  I now have a "random scene mode" (when all 3 pots are at max) that changes the image every 7 seconds.  And I am able to go back to "manual mode" by moving any pot away from max.
The 7 second delay that holds the random image, however, means I don't have manual control until 7 seconds after moving pot away from max.
Is there an easy fix to ensure the device returns to manual mode sooner while leaving the 7 second "hold" of a random scene?
Here is my code:
Code: [Select]
    int potpin1 = 8;
    int potpin2 = 9;
    int i;
    int val1;
    int val2;
      //Serial.begin(9600);
         delay(7000);
    delay(15);
   //Serial.println (val1);
   //Serial.println (val2);
   //Serial.println (val3);
You guys have been really helpful!
Thanks!!
-e
