Topic: trying to make a boarduino (Read 874 times) previous topic - next topic
crxksa
Jun 19, 2011, 10:10 pm Last Edit: Jun 19, 2011, 10:27 pm by crxksa Reason: 1
hi
i am trying to make a boarduino
i have already BIT BANG the IC with my other arduino and uploaded a simple blink code and it worked fine.
but when i put all in a breadboard its not working
here the pic
http://imageshack.us/photo/my-images/843/20110618003.jpg/
mmcp42
a bit hard to see what's going on
do you have a schematic picture?
also take a look at the resistor that is probably the current limiter for the LED in the top right corner
seems to me it is connected between ground and 5 volts!
there are only 10 types of people
them that understands binary
and them that doesn't
retrolefty
Have you made certain of the caps size used with the crystal, lots of people misread the value on the caps.
Lefty
floresta
#3
Jun 20, 2011, 03:45 am Last Edit: Jun 20, 2011, 03:48 am by floresta Reason: 1
The Boarduino (and all other good designs) has four 0.1uF bypass capacitors, your circuit has none.
Don't you somehow have to supply power to the input of your voltage regulator?
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
