Topic: Help - Nokia 1100 lcd - PCF8814 (Read 13794 times) previous topic - next topic
charliec114
Jun 20, 2011, 02:35 am Last Edit: Jun 28, 2011, 03:23 pm by charliec114 Reason: 1
Someone can help me with the schematics to connect the lcd  :(
http://www.freeduino.de/blog/nokia-1100-lcd-display
on page I leave there are examples of code, a schematic would help me a lot to understand.
I am a rookie with arduino, thanks for your time...
// Arduino pinout // Nokia 1100 LCD pinout (VDD & VDDI ==> 3.3V, VLED+ connected via 10 ohm resistor to 3.3V)
:~#define PIN_SCE 10 // 2 XCS Connected via resistor-voltage-divider 1.8K & 3.2K :~
#define PIN_SDIN 11 // 4 SDA
#define PIN_RESET 12 // 1 XRES
#define PIN_SCLK 13 // 5 SCLK
sorry for my english  :smiley-sweat:
lundgaaj
See if this is helpful for you. Attached jpg.
Note that I use the following Arduino pinout: (But can be any of your own choice)
#define PIN_SCE 9        // 2 XCS Connected via resistor-voltage-divider 1.8K & 3.2K
#define PIN_SDIN 10     // 4 SDA
#define PIN_RESET 8    // 1 XRES
#define PIN_SCLK 11    // 5 SCLK
charliec114
many thanks, I'll be testing soon and will surely be counting on you here, thank you very much, I really needed  XD XD XD XD
dudeman420
i have one of these hooked up to my arduino and cant get the code to compile :( im sure its just something simple but
the first one on that link gives me
sketch_mar12a.cpp: In function 'void LcdCharacter(char)':
sketch_mar12a:116: error: invalid conversion from 'const byte*' to 'byte'
sketch_mar12a:116: error: initializing argument 2 of 'void LcdWrite(byte, byte)'
and the second one tells me
sketch_mar12a.cpp: In function 'void LcdPixel(byte, byte, int)':
sketch_mar12a:559: error: invalid conversion from 'byte*' to 'byte'
sketch_mar12a:578: error: incompatible types in assignment of 'byte' to 'byte [780]'
i will repost the code here for simplicity
dudeman420
the first is
line 117
the second one is
line 560
data = LcdCache
dudeman420
#5
Mar 12, 2012, 11:20 pm Last Edit: Mar 14, 2012, 02:10 pm by dudeman420 Reason: 1
got it
Code: [Select]
// Arduino Dueminalove Atmega328
// Interfacing with the Nokia 1100 LCD, PCF8814
#define PIN_SCE 3 // 2 XCS Connected via resistor-voltage-divider 1.8K & 3.2K
#define PIN_SDIN 4 // 4 SDA
#define PIN_RESET 5 // 1 XRES
#define PIN_SCLK 6 // 5 SCLK
#define LCD_C LOW // Command
#define LCD_D HIGH // Data
const int buttonPin = 12;     // the number of the pushbutton pin
static const byte ASCII[][5] ={
{0x00, 0x00, 0x00, 0x00, 0x00} // 20
,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ←
,{0x78, 0x46, 0x41, 0x46, 0x78} // 7f →
int buttonState = 0;         // variable for reading the pushbutton status
void LcdCharacter(char character)
  LcdWrite(LCD_D, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(LCD_D, ASCII[character - 0x20][index]);
void LcdClear(void){
for (int index = 0; index < 864 ; index++)
void LcdInitialise(void){
digitalWrite(PIN_RESET, LOW);
digitalWrite(PIN_RESET, HIGH);
LcdWrite(LCD_C, 0x23); // CONTRAST?
LcdWrite(LCD_C, 0x2F); // Charge pump ON
LcdWrite(LCD_C, 0x24); // Vop MSB *Don't change*
LcdWrite(LCD_C, 0x80); // Vop LSB *Here you can change contrast*
LcdWrite(LCD_C, 0xA4); // A4 = normal display mode, A5 = all pixels ON
LcdWrite(LCD_C, 0xAF); // Display ON
void LcdString(char *characters){
while (*characters){
LcdCharacter(*characters++);
void LcdWrite(byte dc, byte data){
digitalWrite(PIN_SDIN, dc); // dc is sampled with the first rising SCLK edge
digitalWrite(PIN_SCE, LOW); // LCD enable
digitalWrite(PIN_SCLK, HIGH); // First rising SCLK edge
digitalWrite(PIN_SCLK, LOW);
shiftOut(PIN_SDIN, PIN_SCLK, MSBFIRST, data); // SDIN is sampled at the rising edge of SCLK.
digitalWrite(PIN_SCE, HIGH);
void setup(void){
pinMode(PIN_SCE, OUTPUT);
pinMode(PIN_RESET, OUTPUT);
pinMode(PIN_SDIN, OUTPUT);
pinMode(PIN_SCLK, OUTPUT);
pinMode(buttonPin, INPUT);
LcdInitialise();
LcdClear();
LcdWrite(LCD_C, 0xA7); // Inverted display
delay(200);
LcdWrite(LCD_C, 0xA6); // Normal display
void loop(void){
buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    LcdClear();
    LcdString(":-)DAMNIT I SAID DONT DO THAT !!");
    delay(2500);
    LcdInitialise();
    LcdClear();
  else {
    // turn LED off:
    LcdString("DONT PUSH MY BUTTONS");
    LcdInitialise();
this one also has a button routine
pechurc
I have adapted the GFX library from adafruit for the PCF8814 :D i have uploaded it to github
https://github.com/pechurc/Nokia1100-Library
Here u can see an video in action :P
http://www.youtube.com/watch?v=h70XW1VhQM0
bavovna
#7
Jul 22, 2012, 10:25 am Last Edit: Jul 22, 2012, 10:29 am by bavovna Reason: 1
This thread helped me connect the lcd to my arduino uno!
Schematics from PokePjerrot worked perfectly! Thank you!
I used 3.0 and 1.6 kohm resistors instead of 3.3 and 1.8.
Now I will need to figure out how to get 3.3 volts on my DIY Arduino s3v3.
bavovna
hi everyone!
pechurc posted a video with nokia 1100 lcd showing sensor values.
I'm trying to do the same thing - show values from different sensors on the lcd.
My lcd is already connected and working fine. It shows static message from the test sketch.
Code: [Select]
LcdString("ARDUINO UNO R3  SMD + NOKIA 1100 LCD. HELLO FROM UKRAINE!");
    LcdInitialise();
Now I would like to take a sensor value (integer data type) and show it on the lcd screen, but I can't figure out how to do that.
For example:
Code: [Select]
void loop(void){
sensorValue = analogRead(sensorPin);
LcdString(sensorValue); // ??? I know it is not correct, but how do I do this???
LcdInitialise();
delay(100);
When I verify the sketch in Arduino IDE, it gives me an error message: "error: invalid conversion from 'int' to 'char*'"
Please could you explain me how I should convert "int" to "char"?
Maybe you could send me some example sketch?
Thanks beforehand!
bavovna
today I uploaded my test sketch (with library from pechurc) to Arduino Uno and it worked!!! So the issue is not in the code, but in my self-made Arduino s3v3.
It is strange because other sketches worked absolutely fine on both Uno and s3v3.
Does anyone know why this code works on UNO but not on s3v3 (Severino)?
Code: [Select]
#include <Nokia2.h>
LCD Display = LCD();
const int sensorPin = A0;    // pin that the sensor is attached to
// variables:
int sensorValue = 0;         // the sensor value
int sensorMin = 1023;        // minimum sensor value
int sensorMax = 0;           // maximum sensor value
int time = 0;
int lastTime = 0;
  // photocell calibration. This code is copied from http://arduino.cc/en/Tutorial/Calibration
// turn on LED to signal the start of the calibration period:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  // calibrate during the first five seconds
  while (millis() < 5000) {
    // record the maximum sensor value
    if (sensorValue > sensorMax) {
      sensorMax = sensorValue;
    // record the minimum sensor value
    if (sensorValue < sensorMin) {
      sensorMin = sensorValue;
  // signal the end of the calibration period
  digitalWrite(13, LOW);
  //end of calibration
  Display.Setup();
  Display.Clear();
  Display.print ("Hello From Argentina! I'm Axel");
  Display.Update();
  Display.setCursor(0,17);
  Display.print("Hello from Ukraine! I'm Olexiy");
  Display.Update();
eedge
I got the LCD to work but the contrast is very low and you can only see light gray letters. How do u set contrast settings. its bit unclear in datasheet. thank you.
eedge
got it fixed. juz changed the
to
LcdWrite(LCD_C, 0x87); // Vop LSB *Here you can change contrast*
dhenry
Quote
While specified for 3.3v, those devices work fine at 5v.
imasu
#13
May 17, 2013, 11:33 am Last Edit: May 17, 2013, 06:01 pm by imasu Reason: 1
i maybe necro posting here....
i tryed to use pechurc lib but it wont work for the new version of arduino
annyone that can help me edit it so it works ?
i'm kinda new to  this all  so recoding this for me is a bit  to advanced
thanx in advance
and sorry for the horrible spelling and gramae
this is the error that i get
BareMinimum.cpp.o: In function `LCD':
D:\Users\Kitsune\Desktop\arduino-1.0.4\libraries\Nokia1100_Library_master/Nokia2.h:27: undefined reference to `vtable for LCD'
BareMinimum.cpp.o: In function `loop':
D:\Users\Kitsune\Desktop\arduino-1.0.4/BareMinimum.ino:54: undefined reference to `LCD::setCursor(int, int)'
D:\Users\Kitsune\Desktop\arduino-1.0.4/BareMinimum.ino:58: undefined reference to `LCD::Update()'
BareMinimum.cpp.o: In function `setup':
D:\Users\Kitsune\Desktop\arduino-1.0.4/BareMinimum.ino:44: undefined reference to `LCD::Setup()'
D:\Users\Kitsune\Desktop\arduino-1.0.4/BareMinimum.ino:46: undefined reference to `LCD::Clear()'
D:\Users\Kitsune\Desktop\arduino-1.0.4/BareMinimum.ino:48: undefined reference to `LCD::Update()'
svato1979
Hello, I know that´s an old post, but when I use the function "void setTextSize(uint8_t s);" in  the pechurc´s library, characters appear on the screen overlapping each other. Is there a way to solve this issue somehow? I did a trial by adding some space in between letters or numbers and this solved the issue, but if I want to show some value coming from sensors, there is no way to separate them each other. What can I do in this void for avoiding this phaenomenon:
"void LCD::setTextSize(uint8_t s) {
  textsize = (s > 0) ? s : 1;
