Topic: Temperature readings (Read 2366 times) previous topic - next topic
uink
I'm having a little trouble hooking up my 10k themistor and resistor to my UNO, but I think i got it.  I am trying to sense the ambient temperature.  I am using a code that i used in a LilyPad project, so i know the code works.  However, when i run the code with my UNO, this is what I get:
Temp reading = 1023 - 3.30 volts
279.68 degress C
535.42 degress F
Anyone have any advice?
Thanks
CrossRoads
Assuming 1023 is the analog reading you are getting from the A/D converter, looks like it is just reading 5V, and not doing any resister-divider kind of function.
uink
How do i fix that?
I'm totally new to arduino!
liudr
Since you are new, you need to provide your code and picture of your connections. That's typically needed for an answer. We don't have crystal balls.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
AWOL
Maybe it is just a bit warmer than usual.
Maybe you could post your code and your circuit.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
robtillaart
Please post your code.
think you need to add conditional code, something like
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__)  // the 5 volt devices
 code for 5 Volt devices
#else
 code for 3.3Volt devices
#endif
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
uink
#6
Jun 20, 2011, 03:53 pm Last Edit: Jun 20, 2011, 04:08 pm by ABIA Reason: 1
OK, I need to start thinking!!
Sorry, i can't take a picture.  But here are my connections
I have my thermistor in gnd
i have my resistor in a different gnd
I have both of them in analog in (A0)
Here is my code:
Code: [Select]
/* Sensor test sketch
 for more information see http://www.ladyada.net/make/logshield/lighttemp.html
#define aref_voltage 3.3         // we tie 3.3V to ARef and measure it with a multimeter!
//TMP36 Pin Variables
int tempPin = 1;        //the analog pin the TMP36's Vout (sense) pin is connected to
                       //the resolution is 10 mV / degree centigrade with a
                       //500 mV offset to allow for negative temperatures
int tempReading;        // the analog reading from the sensor
void setup(void) {
 // We'll send debugging information via the Serial monitor
 // If you want to set the aref to something other than 5v
 analogReference(EXTERNAL);
void loop(void) {
 tempReading = analogRead(tempPin);
 Serial.print("Temp reading = ");
 Serial.print(tempReading);     // the raw analog reading
 // converting that reading to voltage, which is based off the reference voltage
 float voltage = tempReading * aref_voltage;
 voltage /= 1024.0;
 // print out the voltage
 Serial.print(" - ");
 Serial.print(voltage); Serial.println(" volts");
 // now print out the temperature
 float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset
                                              //to degrees ((volatge - 500mV) times 100)
 Serial.print(temperatureC); Serial.println(" degress C");
 // now convert to Fahrenheight
 float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
 Serial.print(temperatureF); Serial.println(" degress F");
Thanks so much!
robtillaart
Please modify your post, select the code and press # button --> looks so much better
Rob Tillaart
AWOL
Quote
commanda
There's a good write-up here:
http://www.arduino.cc/playground/ComponentLib/Thermistor2
This is my version, where the thermistor goes to ground and the pad resistor goes to positive.
sensorTempValue is already returned from analog read.
Code: [Select]
float calcTempValue;
void calcTemperature()
  // utilizes the Steinhart-Hart Thermistor Equation
  // sample code from Arduino playground Thermistor2
  // this will have to be tested using resistors to simulate the thermistor
  // using values from CityCell's datasheet. (DONE 2011-05-26 AW)
  // As an example, typical values for a thermistor with a resistance of 3000 ? at room temperature (25 °C = 298.15 K) are:
  //  a = 1.40 \times 10^{-3}
  //  b = 2.37 \times 10^{-4}
  //  c = 9.90 \times 10^{-8}
  // float thermR = 3000;            // nominal value of thermistor
  const float pad = 10000;               // value of pull-up resistor
  const float factorA = 1.4E-03;
  const float factorB = 2.37E-04;
  const float factorC = 9.90E-08;
  long resistance;
  float Temp;                      // a local temporary variable
  resistance = sensorTempValue * pad / (1024 - sensorTempValue);   // changed from sample code as our thermistor
  // goes to ground (NOT Vcc)
  // we use 1024  so an open cct thermister won't throw a divide-by-zero error
  Temp = log(resistance);
  Temp = 1 / (factorA + (factorB * Temp) + (factorC * Temp * Temp * Temp));
  calcTempValue = Temp - 273.15;            // convert Kelvin to Celsius
}  // end calcTemperature()
Amanda
liudr
Here's my tutorial with real pictures:
http://liudr.wordpress.com/2011/02/10/measure-temperature/
The circuit shows that your "other ground" is supposed to be 5V.
The R_unknown is the thermistor and R_known is the 10Kohm resistor.
I think you used the wrong code. The code is for a TMP36 sensor, not a thermistor.
liudr
Here is the loop(). You will need Serial.begin(9600); in setup()
Code: [Select]
  float resistance, voltage, r_fixed, T0, T, R0,B;
  T0 = 298.15;//initial temperature for calibration
  R0 = 10000;//initial resistance for calibration
  r_fixed = 10972;//known resistance
  B = 4050;//B for normalization
  Serial.println("Temperature");
  while(1)
    voltage = analogRead(sensor_a)*5.0/1024;// Renormalizing from 0 to 5 volts.
    resistance = voltage*r_fixed/(5.00-voltage);//find unknown resistance
    T = 1/(log(resistance/r_fixed)/B+1/T0)-273.14;//find temperature from unknown ressistance
    Serial.println(T);
I have reconnected my thermistor according to liudr's blog.  However, no code i try is uploading, even codes that were working before!!
What do you mean by not uploading? What error message?
uink
Okay, it is finally uploading again!! Here is the code i uploaded.  However, it still gives me insanely high readings.  What can i do???
BTW, i am on 9600 baud
Code: [Select]
void setup(void) {
void loop(void) {
 voltage /= 1024.0;
liudr
I don't think you read my replies very carefully. You are using the wrong code so re-read my replies and upload the right code.
uink
#14
Jun 20, 2011, 07:31 pm Last Edit: Jun 22, 2011, 05:20 pm by ABIA Reason: 1
I got it working! I needed a different code and resistor.  I posted those details in Sensors under Arudino thermistor.
Thanks to all for their help!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
