Topic: Temperature readings (Read 2899 times) previous topic - next topic
liuzengqiang
I got it working! I changed the voltage (originally at 1024) to like 5000.
Thanks to all for their help!
You must have a peculiar way of defining "working". Whatever you see, if you are truly using a thermistor, is wrong. You used the wrong code and bent it to display a value that you think is right. I offered my help but I don't think you took it all, though. Good luck walking blind on the forum.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
