Topic: What do I need to make a arduino buggy (Read 2820 times) previous topic - next topic
Onkar91
Hey I have an arduino Mega and I recently made a buggy using picaxe at uni. I want to know a list of things I would need to make a buggy. For example, which motors? and would I need a motor driver board... Im new to all this and would appreciate some comments and guidance.
Once Im sure I have all the right stuff i think I can learn the code from tutorials and stuff. and i can put it togther fine
Thanks in advance
AWOL
You could make a simple buggy with a couple of continuous-rotation "servo"s, some wheels and a pack of four AAs or AAAs.
It may not be necessary to use a motor shield.
Onkar91
Whats the difference between a continuous-rotation servo and a motor?
and so will I only need 4 AAs to power the sensors such as IR, LEDs and servos/motors?
AWOL
A continuous rotation "servo" used to be a real servo, so instead of needing a bi-directional driver like an ordinary DC motor would need, it has a simple three-wire interface - power, ground and speed/direction.
It also has gears.
That depends on how many there are, and how long you want them to run for.
PaulS
Most any code posted on the forum this week would do.
Onkar91
Ok. Im from uk, so I wanted to find servos from uk, so that I dont have to pay loads for shipping, and found this:
http://www.robotbits.co.uk/motors-gearboxes/sm-s4303r-continuous-rotation-servo/prod_65.html
If I get two of these..... each for 1 wheel, and I want the buggy to run for at least 40 mins. What power and how would I power it. Im confused bout this. Like Would I not need to power the servos seperately? The Arduino board requires about 6V (if i remember correctly). So If power the arduinoi board with 6V, how will I give extra power to the servos?
The IR sensors take 5V. And I will be using 2. I will also use couple of LEDs
AWOL
It isn't voltage you need to worry about so much, it's amps.
Rechargeable batteries are rated in mAh.
AAs run around 2000mAh and upwards, so for a 100mA current draw, you should be good for 20 hours.
Higher current draw will not scale quite so well.
Another advantage is that cell voltage is a bit lower, so 4 NiMh cells will typically give 5V, not 6.
bubulindo
Why not, checking out how you did the first one and change a few things?
This... is a hobby.
floresta
@Paul: I guess that one went right over their heads - just like their use of the term 'buggy' went right over ours.  If we knew what they were talking about we might be able to help.
Don
Onkar91
Ok, thnx for all your postsso far. Ive been busy so I havnt started nething yet practically with the moving robot I want to make. However I have a few questions whcih I think i need to know the answer to before actually trying to make anything.
Firstly, am I right in thinking that a continuous rotation servo only needs to be connected to one control pin as opposed to a motor, as a motor would coding such as high 1, low 2, to make it go forward/reverse.?
But then can the servo go both foward and back using coding? (I havent looked at coding for servos yet)
Is it possible to connect a motor through the breadboard without a motor driver?, (I have tried to but I coudnt see anyway)
If I use motors, why do i need a gear system? (for example I have a couple of small 5v motors, which I think is one set gear/system/speed)
Im just learning, so help from you pros will be really beneficial  :)
I want to understand the simple stuff, before making it.
Aslo, finally,
I would like to just buy servos, motors, just as spares, so that I can play round with them in future. I only have Arduino mega (ATmega1280), breadboard, 2 simple 5v motors, 3 digital output IR sensors, and LEDs, LDRS, wires etc.
What motors/ any motor drivers/ servos would you recomend?
AWOL
Modded servos are quite nice and easy to drive, but remember that they're not really specced for continuous usage - you may need to replace them dependent on how you (ab)use them.
Metal-geared versions are more robust but a lot more expensive.
You can't drive ordinary DC motors directly from an I/O pin, unless it is a really tiny phone vibra, in which case it won't be able to do much work.
To control a DC motor, use a transistor for a single direction, or an H bridge for bidirectional.
Onkar91
ok. So If i wanted to drive a motor bi-directionally, would I need to get a chip like in the pic at the bottom of this page? http://letsmakerobots.com/node/10023
I will research h-bridges, but if theres a specific chip I need, Could you tell me which one?
AWOL
Fairly popular H-bridge chips are L293D and L298D, but choice of chip depends on choice of motor.
