Loading...
Pages: [1]   Go Down
Author Topic: newbie using Teensy2 as isp for attiny13?  (Read 915 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Im attempting to branch into learning winavr and purchased a attiny13 here http://www.sparkfun.com/products/211
I'm trying to use my teensy 2 from pjrc.com that I have laying around to act as a isp following this guide here
http://www.instructables.com/id/How-to-program-a-AVR-arduino-with-another-arduin/step2/Making-the-mega-isp-programmer-on-a-breadboard/
this guide is different than my hardware but I tried to port it over as best as I could, unfortunately avrdude doesnt seem to like it still
the teensy 2 uses atmega32u4 and im trying to isp attiny13
with all the searching i've done I started changing port locations in the arduino sketch code
so miso is connected to miso, and mosi. in the oringinal guide reset was connected to oc1b so I used that one as well
only issue was I couldnt find a sck on the atmega32u4 but I found a slck and used that...
I'm not using a crystal as it appears not to be compatible according to the amtel doc you attiny13, although sparkfun seems to say different..
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
that said my sketch code is here:
Code:
// this sketch turns the Arduino into a AVRISP
// using the following pins:
// 10: slave reset
// 11: MOSI
// 12: MISO
// 13: SCK
// Put an LED (with resistor) on the following pins:
// 9: Heartbeat - shows the programmer is running
// 8: Error - Lights up if something goes wrong (use red if that makes sense)
// 7: Programming - In communication with the slave
// October 2010 by Randall Bohn
// - Write to EEPROM > 256 bytes
// - Better use of LEDs:
// -- Flash LED_PMODE on each flash commit
// -- Flash LED_PMODE while writing EEPROM (both give visual feedback of writing progress)
// - Light LED_ERR whenever we hit a STK_NOSYNC. Turn it off when back in sync.
// October 2009 by David A. Mellis
// - Added support for the read signature command
// February 2009 by Randall Bohn
// - Added support for writing to EEPROM (what took so long?)
// Windows users should consider WinAVR's avrdude instead of the
// avrdude included with Arduino software.
// January 2008 by Randall Bohn
// - Thanks to Amplificar for helping me with the STK500 protocol
// - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader
// - The SPI functions herein were developed for the AVR910_ARD programmer
// - More information at http://code.google.com/p/mega-isp
#define SCK 1
#define MISO 3
#define MOSI 2
#define RESET 15
#define LED_HB 21
#define LED_ERR 19
#define LED_PMODE 17
#define PROG_FLICKER true
#define HWVER 2
#define SWMAJ 1
#define SWMIN 18
// STK Definitions
#define STK_OK 0x10
#define STK_FAILED 0x11
#define STK_UNKNOWN 0x12
#define STK_INSYNC 0x14
#define STK_NOSYNC 0x15
#define CRC_EOP 0x20 //ok it is a space...
void pulse(int pin, int times);
  Serial.begin(19200);//19200
  pinMode(LED_PMODE, OUTPUT);
  pulse(LED_PMODE, 2);
  pinMode(LED_ERR, OUTPUT);
  pulse(LED_ERR, 2);
  pinMode(LED_HB, OUTPUT);
  pulse(LED_HB, 2);
int error=0;
int pmode=0;
// address for reading and writing, set by 'U' command
int here;
uint8_t buff[256]; // global block storage
#define beget16(addr) (*addr * 256 + *(addr+1) )
typedef struct param {
  uint8_t devicecode;
  uint8_t revision;
  uint8_t progtype;
  uint8_t parmode;
  uint8_t polling;
  uint8_t selftimed;
  uint8_t lockbytes;
  uint8_t fusebytes;
  int flashpoll;
  int eeprompoll;
  int pagesize;
  int eepromsize;
  int flashsize;
parameter;
parameter param;
// this provides a heartbeat on pin 9, so you can tell the software is running.
uint8_t hbval=128;
int8_t hbdelta=8;
void heartbeat() {
  if (hbval > 192) hbdelta = -hbdelta;
  if (hbval < 32) hbdelta = -hbdelta;
  hbval += hbdelta;
  analogWrite(LED_HB, hbval);
  delay(40);
void loop(void) {
  // is pmode active?
  if (pmode) digitalWrite(LED_PMODE, HIGH);
  else digitalWrite(LED_PMODE, LOW);
  // is there an error?
  if (error) digitalWrite(LED_ERR, HIGH);
  else digitalWrite(LED_ERR, LOW);
  // light the heartbeat LED
  heartbeat();
  if (Serial.available()) {
    avrisp();
uint8_t getch() {
  while(!Serial.available());
  return Serial.read();
void fill(int n) {
  for (int x = 0; x < n; x++) {
    buff[x] = getch();
#define PTIME 30
void pulse(int pin, int times) {
  do {
    digitalWrite(pin, HIGH);
    delay(PTIME);
    digitalWrite(pin, LOW);
    delay(PTIME);
  while (times--);
void prog_lamp(int state) {
  if (PROG_FLICKER)
    digitalWrite(LED_PMODE, state);
void spi_init() {
  uint8_t x;
  SPCR = 0x53;
  x=SPSR;
  x=SPDR;
void spi_wait() {
  do {
  while (!(SPSR & (1 << SPIF)));
uint8_t spi_send(uint8_t b) {
  uint8_t reply;
  SPDR=b;
  spi_wait();
  reply = SPDR;
  return reply;
uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) {
  uint8_t n;
  spi_send(a);
  n=spi_send(b);
  //if (n != a) error = -1;
  n=spi_send(c);
  return spi_send(d);
void empty_reply() {
  if (CRC_EOP == getch()) {
    Serial.print((char)STK_INSYNC);
    Serial.print((char)STK_OK);
    error++;
    Serial.print((char)STK_NOSYNC);
void breply(uint8_t b) {
    Serial.print((char)b);
  else {
    error++;
void get_version(uint8_t c) {
  switch(c) {
  case 0x80:
    breply(HWVER);
  case 0x81:
    breply(SWMAJ);
  case 0x82:
    breply(SWMIN);
  case 0x93:
    breply('S'); // serial programmer
  default:
    breply(0);
void set_parameters() {
  // call this after reading paramter packet into buff[]
  param.devicecode = buff[0];
  param.revision = buff[1];
  param.progtype = buff[2];
  param.parmode = buff[3];
  param.polling = buff[4];
  param.selftimed = buff[5];
  param.lockbytes = buff[6];
  param.fusebytes = buff[7];
  param.flashpoll = buff[8];
  // ignore buff[9] (= buff[8])
  // following are 16 bits (big endian)
  param.eeprompoll = beget16(&buff[10]);
  param.pagesize = beget16(&buff[12]);
  param.eepromsize = beget16(&buff[14]);
  // 32 bits flashsize (big endian)
  param.flashsize = buff[16] * 0x01000000
    + buff[17] * 0x00010000
    + buff[18] * 0x00000100
    + buff[19];
void start_pmode() {
  spi_init();
  // following delays may not work on all targets...
  pinMode(RESET, OUTPUT);
  digitalWrite(RESET, HIGH);
  pinMode(SCK, OUTPUT);
  digitalWrite(SCK, LOW);
  delay(50);
  digitalWrite(RESET, LOW);
  delay(50);
  pinMode(MISO, INPUT);
  pinMode(MOSI, OUTPUT);
  spi_transaction(0xAC, 0x53, 0x00, 0x00);
  pmode = 1;
void end_pmode() {
  pinMode(MOSI, INPUT);
  pinMode(SCK, INPUT);
  pinMode(RESET, INPUT);
  pmode = 0;
void universal() {
  int w;
  uint8_t ch;
  fill(4);
  ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]);
  breply(ch);
void flash(uint8_t hilo, int addr, uint8_t data) {
  spi_transaction(0x40+8*hilo,
  addr>>8 & 0xFF,
  addr & 0xFF,
  data);
void commit(int addr) {
  if (PROG_FLICKER) prog_lamp(LOW);
  spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0);
  if (PROG_FLICKER) {
    delay(PTIME);
    prog_lamp(HIGH);
« Last Edit: June 20, 2011, 05:17:50 pm by razrburn » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Code:
//#define _current_page(x) (here & 0xFFFFE0)
int current_page(int addr) {
  if (param.pagesize == 32) return here & 0xFFFFFFF0;
  if (param.pagesize == 64) return here & 0xFFFFFFE0;
  if (param.pagesize == 128) return here & 0xFFFFFFC0;
  if (param.pagesize == 256) return here & 0xFFFFFF80;
  return here;
void write_flash(int length) {
  fill(length);
    Serial.print((char) STK_INSYNC);
    Serial.print((char) write_flash_pages(length));
    error++;
    Serial.print((char) STK_NOSYNC);
uint8_t write_flash_pages(int length) {
  int x = 0;
  int page = current_page(here);
  while (x < length) {
    if (page != current_page(here)) {
      commit(page);
    flash(LOW, here, buff[x++]);
    flash(HIGH, here, buff[x++]);
    here++;
  commit(page);
  return STK_OK;
#define EECHUNK (32)
uint8_t write_eeprom(int length) {
  // here is a word address, get the byte address
  int start = here * 2;
  int remaining = length;
  if (length > param.eepromsize) {
    error++;
    return STK_FAILED;
  while (remaining > EECHUNK) {
    write_eeprom_chunk(start, EECHUNK);
    start += EECHUNK;
    remaining -= EECHUNK;
  write_eeprom_chunk(start, remaining);
  return STK_OK;
// write (length) bytes, (start) is a byte address
uint8_t write_eeprom_chunk(int start, int length) {
  // this writes byte-by-byte,
  // page writing may be faster (4 bytes at a time)
  fill(length);
  prog_lamp(LOW);
  for (int x = 0; x < length; x++) {
    int addr = start+x;
    spi_transaction(0xC0, (addr>>8) & 0xFF, addr & 0xFF, buff[x]);
    delay(45);
  prog_lamp(HIGH);
  return STK_OK;
void program_page() {
  char result = (char) STK_FAILED;
  int length = 256 * getch() + getch();
  char memtype = getch();
  // flash memory @here, (length) bytes
  if (memtype == 'F') {
    write_flash(length);
    return;
  if (memtype == 'E') {
    result = (char)write_eeprom(length);
      Serial.print(result);
      error++;
    return;
  Serial.print((char)STK_FAILED);
  return;
uint8_t flash_read(uint8_t hilo, int addr) {
  return spi_transaction(0x20 + hilo * 8,
    (addr >> 8) & 0xFF,
    addr & 0xFF,
    0);
char flash_read_page(int length) {
  for (int x = 0; x < length; x+=2) {
    uint8_t low = flash_read(LOW, here);
    Serial.print((char) low);
    uint8_t high = flash_read(HIGH, here);
    Serial.print((char) high);
    here++;
  return STK_OK;
char eeprom_read_page(int length) {
  // here again we have a word address
    int addr = start + x;
    uint8_t ee = spi_transaction(0xA0, (addr >> 8) & 0xFF, addr & 0xFF, 0xFF);
    Serial.print((char) ee);
  return STK_OK;
void read_page() {
  char result = (char)STK_FAILED;
  if (CRC_EOP != getch()) {
    error++;
    return;
  if (memtype == 'F') result = flash_read_page(length);
  if (memtype == 'E') result = eeprom_read_page(length);
  return;
void read_signature() {
    error++;
    return;
  uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00);
  uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00);
  Serial.print((char) middle);
  uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00);
  Serial.print((char) STK_OK);
int avrisp() {
  uint8_t data, low, high;
  uint8_t ch = getch();
  switch (ch) {
  case '0': // signon
    error = 0;
    empty_reply();
  case '1':
    if (getch() == CRC_EOP) {
      Serial.print("AVR ISP");
  case 'A':
    get_version(getch());
  case 'B':
    fill(20);
    set_parameters();
    empty_reply();
  case 'E': // extended parameters - ignore for now
    fill(5);
    empty_reply();
  case 'P':
    start_pmode();
    empty_reply();
  case 'U': // set address (word)
    here = getch() + 256 * getch();
    empty_reply();
case 0x60: //STK_PROG_FLASH
    low = getch();
    high = getch();
    empty_reply();
  case 0x61: //STK_PROG_DATA
    data = getch();
    empty_reply();
  case 0x64: //STK_PROG_PAGE
    program_page();
  case 0x74: //STK_READ_PAGE 't'
    read_page();
  case 'V': //0x56
    universal();
  case 'Q': //0x51
    error=0;
    end_pmode();
    empty_reply();
  case 0x75: //STK_READ_SIGN 'u'
    read_signature();
  // expecting a command, not CRC_EOP
  // this is how we can get back in sync
  case CRC_EOP:
    error++;
  // anything else we will return STK_UNKNOWN
  default:
    error++;
      Serial.print((char)STK_UNKNOWN);
« Last Edit: June 20, 2011, 05:19:37 pm by razrburn » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
//////////////////////AVRDUDE OUTPUT/////////////////////////////
//////avrdude  -b 19200 -P /dev/cu.usbmodem12341 -p t13 -c avrisp -v/////
Mc:~ amanda$ avrdude -P /dev/cu.usbmodem12341 -p t13 -c avrisp -v
avrdude: Version 5.8cvs, compiled on Jan 15 2010 at 17:27:01
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/local/CrossPack-AVR-20100115/etc/avrdude.conf"
         User configuration file is "/Users/amanda/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem12341
         Using Programmer              : avrisp
         AVR Part                      : ATtiny13
         Chip Erase delay              : 4000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no         64    4      0  4000  4000 0xff 0xff
           flash         65     6    32    0 yes      1024   32     32  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel AVR ISP
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny13
// at times this line usually says the device 0x000000 doesn't match
//today it is acting a little strange with the programmer not responding, while I was at work my ferret fought with my //attiny13 and has bent all the pins out of wack.. maybe she was packing some electro static in her teeth as well.. im going //to double check the wiring joints again cause at time she tries to steal my teensy of the desk too... I'm on the verge of //jumping for a programmer... this is a last ditch effort for me build a isp
//So besides the unknown fate of the attiny does anyone have a idea what might be wrong with my layout..yesterday I //checked it over with a ohm meter and it appeared all the connections where in excellent order..
« Last Edit: June 20, 2011, 05:03:54 pm by razrburn » Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Yikes!  Please modify your posts and wrap the source code in "code tags".  You can insert "code tags" by clicking the # button above the edit window.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
sorry about that, I hope that helps some i'm limited to 9600 characters per post...
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Thank you.  That is much better.
Quote
I believe the protocol is supposed to be "stk500v1".
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
so far I'm getting the same response, let me hold this off till I can get a replacement avr.. my connections still appear good, ive even reflashed the teensy the isp firmware and again I'm still getting the isp to freeze up during communication.. I'm going to start shopping around for a programmer I think, or I might wait till I need more parts a 3$ tiny's s/h alone is 4$ at sparkfun seems kind of high for one item...
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
For what it's worth, I use a Teensy to program ATtiny85 processors via a modified Arduino ISP sketch.  Once you get the kinks worked out, it works very well.  There are some advantages to using a Teensy instead of a dedicated programmer.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
well attiny85 doesnt sound bad, if you dont mind me asking how do you have it all wired up, and would you being willing to share the sketch you used... I really think my attiny13 must be dead, my ferret must have killed it...  do you have a original teensy or teensy2?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I like em!
Quote
Let's see...
VCC is common (+5 V from USB)
GND is common (also from USB)
0.1 uF capacitor across VCC and GND on the Tiny
SCLK (Teensy) to SCK (Tiny: PB2; pin 2)
MISO (Teensy) to MISO (Tiny: PB1; pin 1)
MOSI (Teensy) to MOSI (Tiny: PB0; pin 0)
SS (Teensy) to RESET (Tiny: PB5)
The Teensy side is labeled (SCLK, MISO, ecterera) on the the board.
Quote
Let me see ... nope.  When I last touched it I was running experiments with on it and it currently does not even compile.  I do remember that I only had to change the LED assignments...
Code:
#define LED_HB 0
#define LED_ERR 19
#define LED_PMODE 18
...and setup to get it working...
Code:
//rmv  Serial.begin( 19200 );
  Serial.begin( 115200 );
  pulse(LED_ERR, 2);
  pulse(LED_HB, 2);
Quote
 smiley-grin  Better that than the dog ate it!
Quote
Very original Teensy (not ++ not 2).
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
Attiny85's are great fun, they have a decent amount of code space and such (plus Coding Badly's attiny85 core results in compiled sizes quite a bit lower than the arduino core for 328s), but still nice and cheap like the smaller tinys.
Less painful to nuke a $2 chip than a $5 chip, plus they take up a lot less breadboard room.
(So far I've only nuked one chip, that was a 328 though.  It actually still works except arduino pins 3 and 4 are quite dead for all functions.  Heard a genuine "snap" of a spark while connecting something.
Logged
Pages: [1]   Go Up
Print
Jump to:
