Loading...
Pages: [1]   Go Down
Author Topic: Serial Debug Macro  (Read 513 times)
Offline Offline
Newbie
View Profile
For debugging, it's handy to print debug messages to the serial port and track down problems. But if you want to trigger the debugging on and off it becomes annoying to comment, and uncomment those Serial.print and Serial.println statements. I wrote this macro that can help in triggering the debugging by simply changing the #define SERIAL_DEBUG_ENABLED  value to 0 or 1. The macro code is :
Code:
#define SERIAL_DEBUG_ENABLED 1
#define GET_NUM_ARGS(...) GET_NUM_ARGS_ACT(__VA_ARGS__, 5,4,3,2,1)
#define GET_NUM_ARGS_ACT(_1,_2,_3,_4,_5,N,...) N
#define macro_dispatcher(func, ...) \
            macro_dispatcher_(func, GET_NUM_ARGS(__VA_ARGS__))
#define macro_dispatcher_(func, nargs) \
            macro_dispatcher__(func, nargs)
#define macro_dispatcher__(func, nargs) \
            func ## nargs
#if SERIAL_DEBUG_ENABLED
  #define DebugPrint(...) macro_dispatcher(DebugPrint, __VA_ARGS__)(__VA_ARGS__)
  #define DebugPrintln(...) macro_dispatcher(DebugPrintln, __VA_ARGS__)(__VA_ARGS__)
  #define DebugPrint2(str,modifier)  \
        Serial.print(millis());     \
        Serial.print(": ");    \
        Serial.print(__PRETTY_FUNCTION__); \
        Serial.print(' ');      \
        Serial.print(__LINE__);     \
        Serial.print(str,modifier);
  #define DebugPrint1(str)  \
        Serial.print(str);
  #define DebugPrintln2(str,modifier)  \
        Serial.println(str,modifier);
  #define DebugPrintln1(str)  \
        Serial.println(str);
#else
#endif
and in your code all you need to do is something like this:
Code:
DebugPrint("The value of x is:");
DebugPrintln(x,DEC);
I hope this helps, let me know if you have any suggestions.
Tarek
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Use PROGMEM for the strings?
Code:
even simpler would be
Code:
#ifdef SERIAL_DEBUG_ENABLED
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Pages: [1]   Go Up
Print
Jump to:
