Topic: LCD TFT Display (Read 4075 times) previous topic - next topic
BNEWBI
I needed helped on how to connect a LCD TFT display to a arduino so that when the LCD display turns on and loads image, it turns off after five seconds. The reason for this is to save battery because the LCD remains on. Please help thanks!
This is my code:
Code: [Select]
#include <ST7735.h>
#include <SD.h>
#include <SPI.h>
#define sclk 13
#define mosi 11
#define rst 8
#define cs 10
#define dc 9
// Color definitions
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
// we will share the hardware SPI interface
ST7735 tft = ST7735(cs, dc, rst);
//  connect the SD card with MOSI going to pin 11, MISO going to pin 12 and SCK going to pin 13 (standard)
//  Then pin 4 goes to CS (or whatever you have set up)
#define SD_CS 4    // Set the chip select line to whatever you use (4 doesnt conflict with the library)
// the file itself
File bmpFile;
// information we extract about the bitmap file
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
void setup(void) {
  pinMode(cs, OUTPUT);
  digitalWrite(cs, HIGH);
  // initialize a ST7735R TFT
  tft.initR();
  // Just do a simple test
  tft.writecommand(ST7735_DISPON);
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
    return;
  Serial.println("SD OK!");
  bmpFile = SD.open("IMAGE.bmp");
  if (! bmpFile) {
    Serial.println("didnt find image");
    while (1);
  if (! bmpReadHeader(bmpFile)) {
     Serial.println("bad bmp");
     return;
  Serial.print("image size ");
  Serial.print(bmpWidth, DEC);
  Serial.print(", ");
  Serial.println(bmpHeight, DEC);
  bmpdraw(bmpFile, 0, 0);
void testfastlines(uint16_t color1, uint16_t color2) {
   tft.fillScreen(BLACK);
   for (uint16_t y=0; y < tft.height; y+=5) {
     tft.drawHorizontalLine(0, y, tft.width, color1);
   for (uint16_t x=0; x < tft.width; x+=5) {
     tft.drawVerticalLine(x, 0, tft.height, color2);
#define BUFFPIXEL 20
void bmpdraw(File f, int x, int y) {
  bmpFile.seek(bmpImageoffset);
  uint32_t time = millis();
  uint16_t p;
  uint8_t g, b;
  int i, j;
  uint8_t sdbuffer[3 * BUFFPIXEL];  // 3 * pixels to buffer
  uint8_t buffidx = 3*BUFFPIXEL;
  //Serial.print("rotation = "); Serial.println(tft.getRotation(), DEC);
  //set up the 'display window'
  tft.setAddrWindow(x, y, x+bmpWidth-1, y+bmpHeight-1);
  uint8_t rotback = tft.getRotation();
  //tft.setRotation();
  for (i=0; i< bmpHeight; i++) {
    for (j=0; j<bmpWidth; j++) {
      // read more pixels
      if (buffidx >= 3*BUFFPIXEL) {
        bmpFile.read(sdbuffer, 3*BUFFPIXEL);
        buffidx = 0;
      // convert pixel from 888 to 565
      b = sdbuffer[buffidx++];     // blue
      g = sdbuffer[buffidx++];     // green
      p = sdbuffer[buffidx++];     // red
      p >>= 3;
      p <<= 6;
      g >>= 2;
      p |= g;
      p <<= 5;
      b >>= 3;
      p |= b;
     //Serial.print(p, HEX);
      // write out the 16 bits of color
      //tft.drawPixel(i, j, p);
      tft.pushColor(p);
  Serial.print(millis() - time, DEC);
  Serial.println(" ms");
boolean bmpReadHeader(File f) {
   // read header
  uint32_t tmp;
  if (read16(f) != 0x4D42) {
    // magic bytes missing
    return false;
  // read file size
  tmp = read32(f);
  Serial.print("size 0x"); Serial.println(tmp, HEX);
  // read and ignore creator bytes
  read32(f);
  bmpImageoffset = read32(f);
  Serial.print("offset "); Serial.println(bmpImageoffset, DEC);
  // read DIB header
  tmp = read32(f);
  Serial.print("header size "); Serial.println(tmp, DEC);
  bmpWidth = read32(f);
  bmpHeight = read32(f);
  if (read16(f) != 1)
    return false;
  bmpDepth = read16(f);
  Serial.print("bitdepth "); Serial.println(bmpDepth, DEC);
  if (read32(f) != 0) {
    // compression not supported!
    return false;
  Serial.print("compression "); Serial.println(tmp, DEC);
  return true;
// LITTLE ENDIAN!
uint16_t read16(File f) {
  uint16_t d;
  uint8_t b;
  b = f.read();
  d = f.read();
  d <<= 8;
  d |= b;
  return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
  uint32_t d;
  uint16_t b;
  b = read16(f);
  d = read16(f);
  d <<= 16;
  d |= b;
  return d;
sjfaustino
#1
Jul 10, 2011, 12:31 pm Last Edit: Jul 10, 2011, 12:50 pm by sjfaustino Reason: 1
This is my code:
Code: [Select]
#include <ST7735.h>
-- SNIP --
Since you didn't give any info on the LCD Panel's backlight consumption, if it's powered directly from VCC or from an Arduino pin, it's difficult to give any help.
If powered from an Arduino pin, just use PWM to control the backlight intensity, if directly from VCC, control it thru a transistor.
To expand, to control an lcd backlight by pwm, connect one of the arduino pwm outputs to the base of a small npn transistor, connect its collector to vcc, and emitter to positive pin of the lcd. connect negative or common pin of the lcd to ground.
Another possibility is, if the backlight is  controlled by the ST7735, to check if the controller allows a code to switch the light off.
foxbat
Also use command SLPIN (10h). It's documented in the ST7735 datasheet.
