Loading...
Pages: [1]   Go Down
Author Topic: What resistor to use with Optocoupler ?  (Read 372 times)
South Africa
Offline Offline
Sr. Member
View Profile
I am wanting to run a 5vDC circuit with a resistor in series, through the diode side of an optocoupler http://za.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=7085480&x=0&y=0 and then to a switch connected to Ground.
Closing the switch causes current flow which then activates the optocoupler.
What I can't seem to determine is the value of the resistor.
My supply is 5V and I see a "forward voltage" on the spec sheet of 1.25v ( typical ).  But not knowing the correct terms, I can't find the mA value that I need to calc the resistor size.
Help please.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Led current is not to critical, the data sheet shows examples running at 5ma to 20ma. 20 ma is a very common value to run a led at so 5v - 1.25 = 3.75v / .020 = so 188 ohms or higher (up to 750 ohms) should work fine. I think 220 ohms is a common value.
datasheet: http://docs-europe.electrocomponents.com/webdocs/0e52/0900766b80e525f1.pdf
Lefty
Logged
South Africa
Offline Offline
Sr. Member
View Profile
Many Thanks Lefty
Logged
Lancaster, England
Offline Offline
Jr. Member
View Profile
I've been using 330ohm resistors with my 4N25s from the Arduino output pins, just because I had a load of 330ohm resistors sitting in a bag doing nothing.  They work great.
Logged
John
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
I'm all in favor of "works/ use it" answers, but if you are interested in the details...
The LEDs in opto-isolators are quite like "ordinary" LEDs.
Aside: One thing to watch out for: LEDs don't always have the "reverse voltage blocking" "strength" of "ordinary" diodes... This matters if you think an LED can do double duty, and chop an AC signal into a series of half cycles.
Going back to "right resistor"... the details are explained at...
http://www.arunet.co.uk/tkboyd/ele1led.htm
Logged
Lancaster, England
Offline Offline
Jr. Member
View Profile
Yes, details, my first post here and how I came to the 330ohm conclusion.
http://arduino.cc/forum/index.php/topic,56485.msg405337.html
smiley
Logged
John
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
I am not, not without understanding if you are putting any strain on things and just about to blow something up. That is the trouble with a lot of stuff on the internet, it comes from bodgers who have no idea what they are doing and that leads beginners into big mistakes.
Logged
Pages: [1]   Go Up
Print
Jump to:
