Topic: How can I force a print format? (Read 2146 times) previous topic - next topic
cyclegadget
  I have sketched a quick program to output 128 HEX integers "0-7E" . The problem is that I would like to have 00,01,02,.....0F etc. for the integers below 10.  Here is what I am getting:
0'1'2'3'4'5'6'7'8'9'A'B'C'D'E'F'10'11'12'13'14'15'16'17'18'19'1A'1B'1C'1D'1E'1F'20'21'22'23'24'25'26'27'28'29'2A'2B'2C'2D'2E'2F'30'31'32'33'34'35'36'37'38'39'3A'3B'3C'3D'3E'3F'40'41'42'43'44'45'46'47'48'49'4A'4B'4C'4D'4E'4F'50'51'52'53'54'55'56'57'58'59'5A'5B'5C'5D'5E'5F'60'61'62'63'64'65'66'67'68'69'6A'6B'6C'6D'6E'6F'70'71'72'73'74'75'76'77'78'79'7A'7B'7C'7D'7E'
Here is the code:
  Serial Call and Response in ASCII
L
int talk = 0;    // output int
int inByte = 0;  // just a place to store input for later
  // start serial port at 9600 bps:
  // if we get a valid byte, read analog ins:
  if (Serial.available() > 0) {
    // get incoming byte:
    inByte = Serial.read();
  while (talk < 127){
    Serial.print(talk, HEX);
    Serial.print("'");
talk = talk + 1;
Thanks for any help'
Mark
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
RuggedCircuits
How about:
while (talk < 127){
    if (talk < 16) Serial.print("0");
    Serial.print("'");
talk = talk + 1;
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
cyclegadget
Thank you for the bullet fast response! I put the code in and it is exactly what I wanted!
One of these days I will realize that not everything has to be difficult.   :smiley-red:
Thanks,
Mark
bubulindo
sprintf() might do that if you specify leading zeros.
The previous response is, however, way more efficient. :)
This... is a hobby.
liuzengqiang
I would check out sprintf since if I end up trying to do 3-digit hex numbers, I'll be making minimal changes from 2-digits if I used sprintf :)
cyclegadget
  Thanks for the idea of sprintf(). I will test that out too. I think I have seen that used in a sketch posted on the forum.
Thanks,
Mark
bubulindo
on printf it would look like:
printf("%02X \n", 10);
I saw this somewhere a few days ago. I'm not sure if it was here or on a general programming forum. Give it a go.
This... is a hobby.
liuzengqiang
printf in regular computers outputs to default output device, the screen. But since arduino has no default output device, it should do nothing even if it exists. You should use sprintf, which outputs to string, thus the s-printf. Just like scanf would scan from default input, the keyboard, on a regular computer, and doesn't do anything on an arduino. But if you want to recognize numbers, say from serial input, you can do sscanf, the string scanf to pick numbers from a sentence.
robtillaart
printf() can be set to work (to certain extent) - http://www.arduino.cc/playground/Main/Printf -
Rob Tillaart
