Topic: serial monitor to text file (Read 44805 times) previous topic - next topic
subrock
Hello, I was wondering if there was an easy way to output the results in the serial monitor to a text file?
Seems like there should be an easy way of doing that..
thanks for the help and sorry if its been asked before. didn't come up in a search.
jds
This is what I do: I receive data coming from Arduino into Hyperterminal. When finished, I copy/past the received data into notepad and save it for later use.
tomek
hej,
a little bit more fancy way would be to write a small little program in processing which receive all the data from the serial port and print it to a text file,
if you want i can pass the code to you, but on the other hand it is really easy, you know the processing GUI  is the same as for Ardunio,
ha det bra
tomek
mlb
emacpher
I haven't actually tried this, but you should be able to pipe input from a serial port directly to a file by typing something like
COPY COM1 filename.txt
at the "DOS" command line. A Ctrl-Z (hex character 0x1A, ASCII  26) coming in will close the file.
See http://chrio.org/serial/ for ideas.
big_mark_h
If you use hyperterminal then it is easy to save any incoming serial data. Just connect to your Arduino, and then go to the 'Transfer->Capture Text' menu option. Select a file to save your data and away you go! All incoming serial data will then be automatically saved for you.
mrmeval
Probably illegal but in fedora linux at 9600 baud for standard ascii characters:
tail -f /dev/ttyUSB0 > myfile
to append
tail -f /dev/ttyUSB0 >> myfile
To watch it in another terminal do
tail -f myfile
If they're not standard covert them to decimal or something. You can even output data to a cvs format if you're a bit creative.
yashar
Can anyone send me program code to save serial port data in text file format please?
Yashar
MikMo
If you are on a Windows system, GoBetwino can do that:
http://www.mikmo.dk/gobetwino.html
robtillaart
If you have python installed a small script does the job. Below a capture-script for an Arduino generated csv file.
Python - http://www.python.org/ -
Serial Lib - http://pyserial.sourceforge.net/ -
import sys, os, serial, threading
def monitor():
   ser = serial.Serial(COMPORT, BAUDRATE, timeout=0)
   while (1):
       line = ser.readline()
       if (line != ""):
           #print line[:-1]         # strip \n
           fields = line[:-1].split('; ');
           // ID = fields[0]
                 // TIME = int(fields[1])
           # print fields
           print "device ID: ", ID
           # write to file
           text_file = open("Pdata.log", "w")
           line = str(TIME) + ": " + str(CT) + "\n"
           text_file.write(line)
           text_file.close()
       # do some other things here
   print "Stop Monitoring"
MAIN APPLICATION
print "Start Serial Monitor"
print
COMPORT = 4;
BAUDRATE = 115200
monitor()
Rob Tillaart
