Topic: Another photo flashgun question (Read 924 times) previous topic - next topic
evilvet
Hi all
I am trying to trigger a photo flash gun that simply requires the short of the pins on the hot shoe.
The circuit I am using is based on the Uno driving a 6N138 optocoupler. An LDR paired with a 10k resistor and a laser pointer gives me a range of values on A0 from 500 to 950 when the beam is broken
This code
int sensorPin = 0;
int sensorValue = 0;
int cameraTrigger =  13;
   pinMode (cameraTrigger, OUTPUT); }
   sensorValue = analogRead(sensorPin);
   if (sensorValue > 900) {
     digitalWrite (cameraTrigger, LOW);
     digitalWrite (cameraTrigger, HIGH);
Seems to work fine, pin 13 goes high just as expected and when I add an LED as a test as per the attached PDF, it does just what I expect it to do.
I cannot work out how to wire in the flash gun, it is just two leads that when shorted fire the flash.
Any advice much appreciated.
retrolefty
Everything you even needed to know about flashguns. Including different flash trigger circuit suggestions way down the document. Basically it is a two terminal interface what has to have a 'standoff' voltage rating => then the flashes hotshoe voltage.
http://repairfaq.cis.upenn.edu/Misc/strbfaq.htm#strboaof
evilvet
Thanks but I don't need a flashgun circuit, I simply need the optoisolator to act as a very fast relay, when D13 goes high the other side of the gate has to close fast and stay closed only as long as the pin stays high
retrolefty
Search that link for the section:
"Optoisolated Remote Trigger from low Voltage Logic or Signal"
It covers what you said you needed to do in the start of this post, to trigger a hotshoe strobe.
Lefty
AWOL
MOC3020 opto triacs are cheap and simple, and don't mind which way round you connect the flashgun, unlike opto-Darlingtons.
evilvet
Fixed it
SY4090 SSR did the job perfectly with a 150o resistor as a current limiter.
