Loading...
Pages: [1]   Go Down
Author Topic: Constants shared from sketch to library  (Read 413 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
It would be nice if we could use in libraries constants and definitions declared in the sketches. This would let us, among other features:
- Conditionally compile libraries according to user definitions in the sketches.
- Use constant values in libraries that have been defined in the sketches.
Thanks for keeping the good work!!
Daniel.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
A #define XYZ before the include and a #ifdef in the library code should work. Quick test:
Code:
#define XYZ 3
#include <test.h>
  Serial.print(f());
void loop(){}
and a test.h
Code:
// test.h
#ifdef XYZ
int f()
  return XYZ;
#else
int f()
  return -1;
#endif
output is depending on the #define XYZ so it worked (if not defined output = -1 else XYZ)
with #defines you kan define constants of all types - int, float string boolean or even complex macros
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
It's odd that you example works but the following doesn't:
test.h (library)
Code:
#ifdef SKETCHDEF
#define LOCALDEF   SKETCHDEF
#else
#define LOCALDEF   0
#endif
test.cpp (library)
Code:
#include "test.h"
int test(void)
  return LOCALDEF;
mysketch.pdw
Code:
# define SKETCHDEF  3
#include "test.h"
  Serial.flush();
  int res = test();
  Serial.print("test = ");
  Serial.println(res, DEC);
Running "test" from my sketch always returns 0. On the other hand, if I define the body of the test function in test.h instead of test.cpp the above example works. I'm a bit confused.
Thanks again!
Logged
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
I suspect
Code:
# define
is different to
Code:
#define
not least because the first doesn't do what you expect!
(I think)
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Yeah, it was a typo. The original code did contain "#define"
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Quote
Running "test" from my sketch always returns 0. On the other hand, if I define the body of the test function in test.h instead of test.cpp the above example works. I'm a bit confused. Thanks again!
The .cpp file is not merged on source level with your sketch, it compiles to an .o file and get linked. It can only relate to things included.
The .h file on the other hand is merged with the source file (to be able to reference the .o file) so #defines will be visible for the preprocessor and will be taken into account when compiling.
AFAIK the solution to your problem is to define a "myconstants.h" file that is included both in your sketch and in the library.
More clear?
Logged
Rob Tillaart
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks, that's what I guessed, hence my initial post. Anyway, this is just a suggestion for future revisions.
Daniel.
Logged
Pages: [1]   Go Up
Print
Jump to:
