Topic: sine wave generator (Read 11504 times) previous topic - next topic
aphy
Hi. I just want to know if it is possible to output 25 kHz sine wave using arudino Duemilanove? I will use it to drive my ultrasonic sensor. Thanks! :D
AWOL
Does it really need a sine wave?
How clean does it need to be?
Do you have a spec for the transducers?
robtillaart
Rob Tillaart
aphy
I'm using Murata MA40E7r/s transducers. I'm really not sure if it will work on square waves, because i need the + and -
AWOL
Lots of designs use RS232 drivers for this purpose.
AWOL
NB 40kHz (25us cycle time)
aphy
so what's the simplest way to do?
AWOL
Well, depends what you're trying to do. (you haven't said)
The spec says 85V full-whack, but only with a 10Hz repetition rate.
aphy
what I'm trying to do is just to use arduino as replacement for function generator. so I just need to output sine wave using arduino with frequency of 25 kHz.
AWOL
#9
Jun 22, 2011, 01:58 pm Last Edit: Jun 22, 2011, 02:02 pm by AWOL Reason: 1
These devices tend to be very resonant, and 25kHz is a long way off the spec of 40kHz, so it won't be very efficient at 25kHz.
Can you tell us what you want to do with this transducer/sensor pair?
The spec says you can drive it up to 85V, but only with 16 cycles of 40kHz (0.4ms) every 100ms. It will probably ring for at least as long (up to maybe a millisecond) again.
aphy
Honestly, I just thought I would use 25 kHz because I need ultrasound to penetrate wood. Do you know someone who's done something like this before? I mean, I really need help. and what I'm trying to do is a hand-held device and so the first thing that I'm trying to do is make arduino act as a function generator.
Grumpy_Mike
Ultra sound doesn't  penetrate wood.
Hit it with a square wave at 40KHz, it is going to go off at that rate anyway no matter what you hit it with.
AWOL
So why pick a 40kHz transducer?
These things are not like loudspeakers with a roughly flat response across part of the audio spectrum - they peak massively at their resonant frequency; that's what they're designed for.
Generating 40kHz is relatively simple (a simple for loop with some padding will need a little tuning and experimentation), it just depends what else you need to be doing at the same time, but you seem to be avoiding the question.
aphy
ULTRASOUND PENETRATES WOOD.
why are you saying that i'm avoiding your question? i mean what question anyway?
what i am doing may be too simple for you so I just need to know how to generate sine wave using arduino? that's all. thank you
AWOL
Are you saying that the Arduino (which doesn't need to generate a sine wave; you can prove this by switching your sig-gen to square) just needs to generate 40kHz?
You could do that with a 555 and save yourself money.
Do you need continuous 40kHz (in which case you won't be able to use full power), or do you want bursts of maximum power at a PRR of 10Hz?
