Topic: sine wave generator (Read 9304 times) previous topic - next topic
robtillaart
@aphy
Can you explain why you want to penetrate wood ?
Rob Tillaart
aphy
can 555 create nice 40 kHz sine wave? do you have any schematic? thanks
AWOL
#17
Jun 22, 2011, 03:29 pm Last Edit: Jun 22, 2011, 03:35 pm by AWOL Reason: 1
No, a 555 can't generate a nice sine wave at 40kHz, but it has been repeatedly pointed out to you that you don't need a 40kHz sine wave when a 40kHz square wave will do the job just as well.
A 555 will produce a 40kHz square wave.
I just guessing here, but one of us first picked up a pair of Murata 40kHz transducers about thirty years ago and happily drove it with a 555, then an 8080, a Z80, a 6809, a 68000, a PIC and then an Arduino, and one of us didn't.
(Edit: oops missed out T450 transputer)
aphy
ok thank you very much!!! :D
i will try the square wave and the 555 as well.
sorry i'm just afraid to try the square wave because i'm afraid to break my sensor.
but then i guess I'll do it. thanks..
Grumpy_Mike
But the data sheet specifies square waves.
Make that two of us  :)
MGeo
#20
Jun 23, 2011, 12:04 pm Last Edit: Jun 23, 2011, 12:07 pm by MGeo Reason: 1
Hi. I just want to know if it is possible to output 25 kHz sine wave using arudino Duemilanove? I will use it to drive my ultrasonic sensor. Thanks! :D
Did you get an answer to your original question?
Google DDS (for direct digital synthesis), NCO (numeric controlled oscillator) and read up.  These are techniques that let a micro generate programmable sine waves.
Here is a link to a good one http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
The link shows a fancy filter on the output, but you can get away with a simple RC if your not too picky on bandwidth and distortion.  Try it and let us know how it works.
Grumpy_Mike
We established that he did not want to do this at all. Well that is he did not need to do it as a square wave would do equally as well, and that it would have done him no good even if he had generated one.
aphy
@grumpy mike, I've tried the square wave but How can I get 40kHz? I tried the PWM but the frequency is quite low.
aphy
int outPin = 8;                 // digital pin 8
  pinMode(outPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(outPin, HIGH);   // sets the pin on
  delayMicroseconds(25);        // pauses for 25 microseconds
  digitalWrite(outPin, LOW);    // sets the pin off
>>will this program be ok to drive my ultrasonic transmitter?
AWOL
Yes, but at the wrong frequency.
(40kHz == 25us cycle)
aphy
oh yes. that would make it 12.5
AWOL
You'll probably find that you need shorter delays than that (you can't have a x.5us delay anyway) to account for the overheads of "digitalWrite".
aphy
then what could be the best way to do? and amplifier for the square wave? thanks
AWOL
Get hold of an oscilloscope or a frequency counter, and tweak your loop times until you get closest to 40kHz.
MAX232 or similar.
robtillaart
For those frequencies you might also need a look into direct port manipulation: - http://www.arduino.cc/en/Reference/PortManipulation
You must know the pin in advance, but thats not the problem I guess
Rob Tillaart
