Topic: CAN-BUS question (Read 801 times) previous topic - next topic
SilverJester
Hopefully this is the right forum to ask this question. I have a project in mind that will add some features to my car (mitsubishi evo x), but since I've never used an arduino before I want to start on a slightly simpler task. I want to start with simply having the arduino read the vehicle speed off the CAN-BUS and display it to a LCD screen.
My question is, can the arduino be connected directly to the CAN-BUS in some way (not through the ODBII port)? When the project is complete I want it to be more of a permanent install and not interfere with my OBDII port as I use it for data-logging.
Coding Badly
Quote
No.
cyclegadget
  Do some research on OBD2 Arduino. I believe you can show your speed and log with Arduino at the same time. I have only skimmed over it though.
Mark
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
