Topic: "Waking up" waveform (Read 2702 times) previous topic - next topic
denniscj7
I'm looking for a waveform to drive the brightness of leds so the appearance is that the device with the leds is "waking up". I've done a lot of searching and run off on a lot of unproductive tangents. I have to think that many before me have used creative waveforms in a variety of projects. Any ideas on what to search on ?
I'm thinking of a waveform that has a steep, probably linear  rise to get to max brightness and then some sort of rolloff or decay as the brightness diminishes.
This is for a Stars wars like light saber that I have built, programmed and is complete except for this part. I would like for it to "wake up" as a prelude to the light show.
ebird97
Here ya go buddy. Got this from "Getting Started with Arduino" Book. Have fun! hopefully it'll help... :)
// Copy and paste this example into an empty Arduino sketch
#define LED   9 // the pin for the LED
int i = 0;      // We'll use this to count up and down
  pinMode(LED, OUTPUT); // tell Arduino LED is an output
void loop(){
  for (i = 0; i < 255; i++) { // loop from 0 to 254 (fade in)
    analogWrite(LED, i);      // set the LED brightness
    delay(10); // Wait 10ms because analogWrite
               // is instantaneous and we would
               // not see any change
  for (i = 255; i > 0; i--) { // loop from 255 to 1 (fade out)
denniscj7
Thanks, but I'm way beyond that. I've looked at sine, ramp, exponential and combinations and still haven't found what I want. I have and I suspect many others as well seen what I want in Disney and other children's clips.
Thanks for the thought though.
CrossRoads
So why not just write that in setup?
Take ebird97s code, increase the count by 10 instead of 1 so it goes up quicker, than change direction and ramp it down by increments of 1 or 2 down to whatever your pre-show level is.
