Topic: Controlling servos with ServoTimer2 and ServoDecode (Read 992 times) previous topic - next topic
RthuR
Hello,
I am currently trying to have the receiver and the servos of my rc car interface with arduino in order to be able to then convert it to an autonomous vehicle.
I have finally managed (with the help of AWOL) to decode the ppm signal of my receiver with the following sketch made by mem.
Code: [Select]
// ServoDecodeTest
#include <ServoDecode.h>
#undef round
char * stateStrings[] = {
  "NOT_SYNCHED", "ACQUIRING", "READY", "in Failsafe"};
void setup()   // run once, when the sketch starts
  Serial.begin(38400);
  ServoDecode.begin();
    //setFailsafe()  can set a pulse width for a channel if the Tx signal is lost.
    //By default all channels not explicitly set will hold the last good signal
  ServoDecode.setFailsafe(3,1234); // set channel 3 failsafe pulse  width
  int pulsewidth;
  // print the decoder state
  if( ServoDecode.getState()!= READY_state) {
    Serial.print("The decoder is ");
    Serial.println(stateStrings[ServoDecode.getState()]);
    for ( int i =0; i <=MAX_CHANNELS; i++ ){ // print the status of the first four channels
Serial.print("Cx");
Serial.print(i);
Serial.print("= ");
pulsewidth = ServoDecode.GetChannelPulseWidth(i);
Serial.print(pulsewidth);
Serial.print("  ");
    Serial.println("");
  else {
    // decoder is ready, print the channel pulse widths
    for ( int i =1; i <=MAX_CHANNELS; i++ ){ // print the status of the first four channels
Serial.print("Ch");
Serial.print(i);
Serial.print("= ");
Serial.print("  ");
    Serial.println("");
  delay(500); // update 2 times a second
The next step is to control two servos based on this. I have found this sketch also by mem, but the servos aren't responding to any inputs, they just jerk occasionally to one side every 15 - 20 seconds.
Here is the sketch:
Code: [Select]
// ServoDecodeTest
#include <ServoTimer2.h>// the servo library
#undef round
// define the servo pins
#define servo1Pin  5   // the pin the servo is attached to
#define servo2Pin  6
ServoTimer2 servo1;    // declare variables for the servos
ServoTimer2 servo2;
  servo1.attach(servo1Pin);
  servo2.attach(servo2Pin);
  int pulsewidth[MAX_CHANNELS];
    Serial.println("The decoder is not ready");
  else {
    // decoder is ready, do somthing with the channel pulse widths
    if( ServoDecode.GetChannelPulseWidth(1) > 1500){  // run script 1 if pulse width greater than 1500 ;
int argumentA = (2250 - ServoDecode.GetChannelPulseWidth(2)) / 200; // some values proportional to stick position
boolean argumentB = ServoDecode.GetChannelPulseWidth(2) < 1500; // true if channel 2 less than than 1500
runScript1(argumentA, argumentB);
  delay(100); // update 10 times a second
void  runScript1(int argumentA, boolean argumentB){
  // do something here to control servo...
  servo1.write(2000);
  delay(5000);  // note that all servo are pulsed by the interrupt handler with their current value every 20ms
  if(argumentA)
     servo2.write(2000);
  delay(argumentB * 10); //delay a time determined by the transmitter stick position
  servo1.write(1000);
  servo2.write(1000);
Thanks a lot!
Arthur
zoomkat
Quote
bump
Have you been successful at controlling two servos independent of the RC decoding?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
RthuR
Thanks for your reply, sorry for the late anwser...
Yes I have, but not using servotimer2 but with the original servo library. I'll give it a try with servotimer2
Thanks a lot!
Arthur
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
