Author Topic: Intterrupts  (Read 513 times)
Connecticut
RTFD (Datasheet in our case)
What is the difference between a pin-change interrupt and an external interrupt?
Thanks!
baum
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
Massachusetts, USA
The external interrupts are associated with specific interrupt pins.  They can be set to signal on a LOW level, RISING edge, FALLING edge, or CHANGE (both rising and falling edge).
There is one "Pin Change" interrupt per port (8-bit group of I/O pins).  The pins within the group can be individually masked.  The pins are sampled periodically and the interrupt is signaled if any of the un-masked pins has changed.  If you have more than one pin in a port enabled you have to read the interrupt flag register to find out which pin(s) changed.
Connecticut
But on the attiny, every pin has a pcint (pin change interrupt)!!!!
http://www.atmel.com/dyn/resources/prod_documents/2535S.pdf (2ndPage)
Dallas
Shannon Member
Pin-change...
• Applies to all pins
• Overloaded; all pins on a port are vectored through a single interrupt handler
• Fires only on CHANGE
• Processor clock does not need to be running
External...
• Applies to only specific pins
• One-to-one; each pin has a dedicated interrupt handler
• Can be configured to fire on RISING, FALLING, LOW, CHANGE
• Requires the processor clock to be running (except LOW)
Dallas
Shannon Member
Each pin on that processor is capable of generating a pin-change interrupt.  If any pin is configured to generate a pin-change interrupt, when the interrupt occurs, execution is vectored through a single interrupt service routine.
Connecticut
How do I call the ISR and get the pin state?
Is it something like
PCINT << 4?
Dallas
Shannon Member
Are you asking how to enable pin-change interrupts?
digitalRead
Connecticut
So I can use digital read w/ your cores; how do i do pchange interrupts?
Dallas
Shannon Member
You're going to have a tough time using any core with an ATtiny13.  It really does not have much memory (64 bytes of SRAM; 4 bytes are used just getting into loop).  The processor was really meant to be programmed using assembly or possibly "raw" C.
There is an enormous amount of information available regarding pin-change interrupts.
http://www.google.com/search?q=arduino+pin+change
http://www.arduino.cc/playground/Main/PcInt
http://www.arduino.cc/playground/Main/PinChangeInt
http://arduino-tiny.googlecode.com/files/PinChangeInterrupt-0001.zip
http://arduino.cc/forum/index.php/topic,51838.msg369796.html#msg369796
Connecticut
I was talking about the '85... sorry!
So in summary, external interrupts execute certain code when triggered, pin change interrupts are a register that stores the inputs on that port?
Dallas
Shannon Member
In that case, just snag the Pin Change library from the Tiny Core website and play a bit.
Yes.
No.  "Pin change interrupts" also execute certain code when triggered.  The difference is that up to eight pins are tied to a single interrupt service routine and only CHANGE is supported.
