Topic: Traktor Pro Arduino Midi Controller [Not working] (Read 2101 times) previous topic - next topic
hackyhacky
i would like to create my own simple midi controller for the dj software traktor pro. After some minutes i implemented a little sketch:
 Serial.begin(31250);
 pinMode(13, OUTPUT);
 int sensorValue = analogRead(A0);
 int realVal = map(sensorValue, 0, 1023, 0, 20);
 if(realVal >= 10) {
   digitalWrite(13, HIGH);
   noteOn(0x90, 0x1E, 0x45);
   delay(2000);
   //Serial.print(0xFC,BYTE);
   digitalWrite(13, LOW);
void noteOn(int cmd, int pitch, int velocity) {
 Serial.print(cmd, BYTE);
 Serial.print(pitch, BYTE);
 Serial.print(velocity, BYTE);
I use Window 7 and Arduino Duemilanove. SensorValue contains the value from a cheap force sensitive resistor.
Everything works fine and when i press my sensor hard enough a midi message will be transmitted (Serial monitor).
I use MidiYoke and Serial Midi Converter to get a midi device for traktor. When I hit the "Lean Button" in traktor and then press the, nothing happens. I tried every possible combination but i don't get it to work :-(
What i'm doing wrong? Can someone help me please?
Thanks.
robtillaart
Rob Tillaart
hackyhacky
I tried:
   //midi(144, 50, 50);
   //midi(128, 50, 50);
but nothing happens :-(
midi = noteOn();
hackyhacky
hackyhacky
I found it!
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1161023163/30
You have to mod the FTDI USB Driver! Enjoy! :-)
dressale
What did i miss?
__________________
dressale.com vicyc.com  saleomg.com
