Topic: LOADING ARDUINO (Read 871 times) previous topic - next topic
ajishalfred
hi..
Im a beginner in electronics. Im always tensed  while i try to connect arduino board with other circuits, as i think whether the impedance matching issue may cause any damage to the controller.
Please tell me a better and safer way to interface with any kind of loads, also the effective method to measure impedances of circuits.
Thanks in advance....
liuzengqiang
Welcome! I'm not sure if impedance matters at all as much as DC resistance. Tell us what you want to hook up to your arduino we'll tell if it works or it smokes your arduino.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Grumpy_Mike
There is no measurement substitute for knowing what you are doing. You should be able to calculate the load of any device from its data sheet using ohms law.
