Topic: Honeywell HCH 1000 Humidity Sensor (Read 25837 times) previous topic - next topic
cbabilotte
I was wondering if anyone has tips on how to use the  Honeywell hch 1000 with a 555 timer? I am having difficulty trying to wire the hch 1000 correctly with the 555 timer and the arduino uno. Thanks.
robtillaart
Please post
* URL of the sensor
* your code so far
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
cbabilotte
#2
Jun 24, 2011, 03:31 pm Last Edit: Jun 24, 2011, 03:36 pm by cbabilotte Reason: 1
The data sheet for the honeywell can be found at:
http://www.honeywell-sensor.com.cn/prodinfo/sensor_humidity_moisture/datasheet/HCH-1000.pdf
the cmos 555 data sheet can be found at:
http://www.datasheetcatalog.org/datasheet/texasinstruments/tlc555.pdf
Here is the code
const int pin = 3;   // Analog input pin
unsigned long duration;
const int sensor_offset = 1889;  //the offset to give correct RH value
  Serial.begin(9600);   // initialize serial communications at 9600 bps:
  pinMode(pin, INPUT);
  duration = 0;
  byte j = 0;   // for start counter enter digits
  for (j = 0; j < 16 ; j +=1)
  duration += pulseIn(pin, HIGH);
  duration /=16;
  long humid =(duration - sensor_offset)/10.23; //max is 1023 and to %
  Serial.print("sensor = " );
  Serial.print(duration);    // print the adc value to the serial monitor:
  Serial.print("\t humidity = ");
  Serial.print(humid);   // print the temperature
  Serial.println(" %");
  delay(1000);   // wait 1 second before next sample
I have attached the circuit diagram but I am not sure it is correct.
pwillard
Examples of what you can do:
1) http://www.arduino.cc/en/Tutorial/RCtime
2) http://arduino.cc/forum/index.php/topic,55812.0.html
