Topic: Wixel Shield: Make your Arduino Wireless! (Read 12096 times) previous topic - next topic
retrolefty
the limits they mention apply if you're using the on-board regulator(s)
you can just feed 5 volts regulated directly into Vin
Wrong, Vin just feeds to the INPUT of the on-board 5vdc regulator. You can of course feed a regulated +5vdc to the shield +5vdc pin.
looks like I may be going the higher voltage route after all :)
I want to keep running at 16 MHz, hadn't spotted that part!
mmcp42
oops
that is in fact what I meant
it was ok when it left my brain
got distorted once it reached the fingers!
thanks!
there are only 10 types of people
them that understands binary
and them that doesn't
mmcp42
Back on topic, I finally got my seeeduino project taking to the IDE using a pair of wixels.
I followed the user guide (shock horror) and downloaded wireless app 1.3 shield version.
I did have to change the default baud rate to 57600
I also found that a steady red LED seems to keen low voltage AKA time to change the batteries
Onwards and upwards!
Mike
retrolefty
Quote
That is so cool. I have been very tempted to buy a pair of Wixel. The ability to easily change from a IDE to arduino board so that one can upload new sketches wirelessly, or to reconfigure them as a simple arduino to arduino wireless link is sure attractive. I just wish the range was a bit more then 50ft, however maybe they are rating that conservatively?
Lefty
robtillaart
@ lefty,
buy two pair of wixels and maybe you can build yourself some repeaters ... ?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
bens
It's hard to give an exact range because it is affected by a number of variables, including intermediate objects, Wixel orientation (a Wixel sitting flush against a surface might have a slightly different range than if it is a few inches above that surface), and even unit-to-unit variation.  The 50-foot range is meant to be a rough estimate of the range at which a reasonable data rate is still achievable in a typical (somewhat RF-noisy) indoor environment, where the Wixels several rooms apart with a few walls between them.  We tried a pair outside with direct line of sight and were able to achieve good wireless serial communication out to approximately 200 feet, but I don't have any sense for how much this line-of-sight range might vary from unit to unit, so please don't treat this as an official spec.
- Ben
mmcp42
my work station (ok the place where I spent all day slumped over the lap-dancer) is electrically very noisy
laptop
wireless mouse
fast wireless router
bluetooth printer
couple of mobile phones
land line (wireless of course)
my new shiny project works fine with the tethered end in the middle of the mess described above and the "works" in the next room (through a brick wall into another room with mobiles and wirleess handsets)
only 10' or so (ok I couldn't b *rsed to walk any further), but noisy as hell
so two thumbs up from me
Robert10
Hi Bens,
I need your help now.
I have an RF device pair to control on/off a lamp. The transmitter and receiver are used CC2500 chip (I saw CC2500 chip after removing box). And now I want to replicate the transmitter for a spare. The RF devices have no any technical document.
So what should I do to replicate the transmitter?
Thank so much.
Regards,
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
