Topic:  Problem: Arduino & LCD with KS0066 / SPLC780 (Read 15270 times) previous topic - next topic
92888488
I think the problem is, that the LCD I own seems to have an KS0066 controller but it isn't the LCD mentionned in the datasheet. I have to switch the contacts 15 and 16... Also there is a Timing Diagramm printed, but no exactly times mentionned... So what do you think? What do I have to change in the liquidcrystal library to may make it work? (or to exclude a sofware mistake)
greetings kuhni
floresta
Quote
The times are given in the datasheet for the controller, but not always in the datasheet for the module.  If you don't have the specific datasheet for your controller then use the one for the 44780 (http://www.sparkfun.com/datasheets/LCD/HD44780.pdf).
Quote
Nothing.  You might want to try downloading a new copy of the Arduino IDE which will include a new copy of the library.  We are really grasping at straws here but it's worth a try.   You will probably wind up needing another LCD module, from a different supplier, to pin down the problem.
Don
92888488
Hmm... Now tried a new copy of Arduino... Didn't solve the problem, damn! Any other idea, or should I now hav a look on ebay for a new module?  :'(
greetings kuhni
floresta
Quote
That might be your problem right there.  I wouldn't choose one of those for my first attempt at using an LCD.  Once you have your connections and code verified it would be ok.
Don
pracas
Perhaps you should try hard coding it without using the library... it seems to be something with the data / rs lines... did you check continuity on these lines between the controller & the LCD?... i've had similar problems but it was always the connections.....or the way they fit on a breadboard...
92888488
#20
Dec 30, 2010, 10:36 am Last Edit: Dec 30, 2010, 10:38 am by 92888488 Reason: 1
Quote
jap! I did for about a thousand of times! :-)
I now also had a look at the wireing I used to connect it to parallel port of the pc and followed all wires. It is the same connection as in this picture:
http://www.codeproject.com/KB/cs/cspplcds/circuit_with_potentiometer.gif
Except:
- R/W (is wired to pin 14 of the parallel port
- +5V of the backround light. It is pin 16 on my lcd board
- GND of the backround light. (pin 15 on my lcd board) This is wired over a transistor ciruit tu pin 17 of the parallel port.
I would try to hard code it without the library, but I'm unable to find timing schemes of the KS0066 or the SPLC780 module in the net.
greetings kuhni
92888488
Hey
tomorrow, I'll have the chance to buy a new LCD. But I don't know whether it will work with the arduino. The Data- Sheet is: http://www.produktinfo.conrad.com/datenblaetter/175000-199999/183334-da-01-ml-LCD_Modul_4x16_Zeichen_de_en.pdf
Could you please tell me, wheter i should buy this one?
greetings kuhni
floresta
Why wouldn't it work, it's a run of the mill HD44780 clone?   That's an interesting technique they used to make an 8 page data sheet summary out of a 5 page one.
Don
Esonra
Good day.
I looked at your pictures and with the nuwe red wires you did not connect the LCD the same way as with the messy wires  EG RS now go to pin 2 and not 12  and and and
IS THIS not your problem???
