Topic: Siemens SDA 2546-5 EEPROM (Read 3617 times) previous topic - next topic
Luse87
I think it is possible to connect a SDA 2546-5 4kb EEPROM () via I2C to an Arduino,
but what changes from the guideline in http://www.arduino.cc/playground/Code/I2CEEPROM?
I connected the device exactly as indicated above, but I did not managed to get it work via the eeprom.pde.
Thanks in advance, I'm a newbie.  :smiley-red:
robtillaart
Do you have everything connected?
- GND SDA SCL, 5V
Please post the link to the datasheet, - specs should fit code !
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Luse87
Datasheet can be found here: http://www.alldatasheet.com/datasheet-pdf/pdf/168172/SIEMENS/SDA2546-5.html
I connected pins 1-4 to GND, 8 to 5V and SCL/SDA to arduino i2c pin 4 and 5 s as indicated in the tutorial.
Thanks for the quick reply!  XD
robtillaart
Page 4 of the datasheet, you need to connect the Chip Select pin 2 to +5V to select it .... ;)
regards,
Rob
Rob Tillaart
Luse87
I fixed the problem, but no reply from the eeprom.. What about device address? Is 0x50 right?
Sorry for wasting your time with such trivial issues...
Thanks again.
robtillaart
Quote
This sketch is the most important I2C tool - http://todbot.com/blog/2009/11/29/i2cscanner-pde-arduino-as-i2c-bus-scanner/
Quote
He, it''s my choice to answer these questions ;)    And no these are not trivial questions, the answers may be, ...
The next time you know some answers and you can help someone else,
Rob Tillaart
Marco_Benini
Ciao,
has You put the pullup resistors between I2C wires and +5V? (4.7 kOhm are ok as resistors values).
Ciao,
Marco.
Luse87
#7
Jun 26, 2011, 10:40 am Last Edit: Jun 26, 2011, 10:49 am by Luse87 Reason: 1
I tried the i2c scanner and in fact the device is not found.. I'll try to add the pull-up resistor! :/
In the datasheet is indicated only a 10k R between SDA and +5V, must I add another one for SCL? A 10k or 4.7k resistor can be the same?
Thanks for now.
robtillaart
That can easily be tested ;)
Both lines should have a square wave (signal), and if one is distorted due to length or otherwise , the other .......
Rob Tillaart
Luse87
Nothing happens with pullup resistors either 10 or 4.7k, on both SDA and SCL or only on SDA.
:( Device is not found.
Marco_Benini
Ciao,
check again the pin connections.
Pullup resistors are needed on both SDA and SCL lines.
Have connected to the analog 4 and 5 pins of Arduino, not the digitals ones? Beware that if You use Arduino Mega or 2560 I2C pins are not the analog 4 and 5.
Ciao,
Marco.
