Topic: Good book to learn Arduino (Read 11974 times) previous topic - next topic
news_js
Hello!
What book would you advise me so I can learn Arduino? I'm undecided about these three:
«Beginning Arduino»
http://www.amazon.com/Beginning-Arduino-Michael-McRoberts/dp/1430232404/ref=pd_rhf_p_t_3
«Arduino Cookbook»
http://www.amazon.com/Arduino-Cookbook-Michael-Margolis/dp/0596802471/ref=pd_bxgy_b_img_b
«Arduino: A Quick Start Guide»
http://www.amazon.com/Arduino-Quick-Start-Quick-Start-Guides/dp/1934356662/ref=ntt_at_ep_dpt_1
Thanks.
robtillaart
Or - http://www.earthshineelectronics.com/files/ASKManualRev5.pdf -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
liuzengqiang
What is your background in electronics and programming? What do you see as "need improvement" in your skills?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
CrossRoads
Earthshine is at Rev 5 now? What's been updated?
news_js
I learned in school the basics of electricity, such as Ohm's law and Kirchhoff's laws, etc. Then I read some books of basic electronics. The most advanced was the first volume of «Electronic Principles», from Albert Malvino.
About programming I only know the old Basic.
robtillaart
Quote
Don't know, I only downloaded it to be able to reference it.
A quick check shows :
Revision 4 - August 2010
Revision 5 - August 2010
the file size is identical ==> sounds like a typo fix version,
BTW AFAIK there is no ref 6 ;)
Rob Tillaart
liuzengqiang
For programming part, you will need some basic C programming. I suggest you get a book on this topic, a basic one. You can also try to see how far you can go without a C book with the arduino programming notebook.
Your circuits basics sounds sufficient to me.
If you have never done digital logic, boolean math, or seen memory or data type, a basic C programming book should cover those in some detail.
tkbyd
Why not online resources? Many are rather "bitty", not sequenced, true.
I hope the following is an exception...
http://sheepdogguides.com/arduino/FA1main.htm
And the Arduino playground lists others.
simon.monk
You might also like to consider '30 Arduino Projects for the Evil Genius'. http://www.arduinoevilgenius.com.
At least I'd like you to consider it ;)
I write books about Arduino and Electronics: http://simonmonk.org
robtillaart
@si,
Think you should mention you have a commercial interest in the book, no big deal but just to be open about it
Rob Tillaart
simon.monk
@Rob, was I being to subtle?
I am the author of this work.
It is an introduction to Arduino and some of the electronics that you need, not just a project book. I have had good feedback from people using it to learn Arduino, even though that might not be what the title leads you to expect.
Techone
@Si
I own one of your book..."15 Dangeroulsly Mad Projects for the Evil Genuis".  Excellent work, The book give me some ideas.  :)
I will purchase the Ardiuno and the Picaxe. ---> If my budget permitted.
@news_js
Buy all of them. The more knowlege you obtain, the better you become.
buzzdavidson
My 2 cents...
+1 for "Arduino Cookbook"; well written, informative, and useful as a reference as well.
I've also found TronixStuff's Arduino tutorials helpful: http://tronixstuff.wordpress.com/tutorials/
Nothing beats actually getting your hands dirty and building stuff.  Forums and Blogs are excellent sources of inspiration for new ideas, books are great for a foundation, but until you start building your own devices it's all theory.
floresta
You better buy all of the books as suggested if you are going to try to overcome this hurdle:
Quote
Don
Techone
Quote
He's right. You will need some basics tools ( pliers, cutter ), DVM ( Digital Multimeter ), batteries, wires,  breadboard and electroncs parts.   And you are on your way. Start small, step-by-step. Goes also with the programming.
