Loading...
Pages: 1 [2]   Go Down
Author Topic: Troubles with BMP085 pressure sensor & I2C protocol  (Read 1621 times)
Italy
Offline Offline
Newbie
View Profile
WWW
Quote
Can't tell you if you've damaged anything yet but if you did it would typically be the lower voltage devices.
I think so, but now even DS1307 RTC refuse to work... its behaviour is the same of the BMP085, while its supply voltage is 5 V
Logged
Worcester, MA
Offline Offline
God Member
Arduino rocks
View Profile
WWW
What size pullups are you using for the RTC?
Logged
I2C GPS Shield
Checkout my Open Source GPS Tracker on Kickstarter
Italy
Offline Offline
Newbie
View Profile
WWW
10k for both SCL & SDA (obviously one each)
Logged
Italy
Offline Offline
Newbie
View Profile
WWW
Last night, in spite of sleeping, I was thinking about 3.3 level conversion of signal. Should something like the attachment works (apart the mistake that the central resistor should be 220R in spite of 330R)? I even thought that it should work fine for digital output, but dunno know if it's the same for I2C... even thought that a diode should be mounted in parallel to resistor to avoid an extra lowering of 3.3v signal sended from sensor to I2C pins A4 & A5.
I bought a logical level converter, but if the method I thought about works it would be easier for me to integrate it into my own shields...
I'm sorry I tried to read something about I2C protocol but I understand almost nothing when applying it to Arduino.
« Last Edit: July 04, 2011, 05:46:48 am by lucareds7 » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
