Topic: Where do I go with my project? (Read 1 time) previous topic - next topic
tbaldwin102
I've got a project all coded out and I want to move it and put it to use, yet I want to keep my arduino. I know there are cheap alternatives but I don't know what they are. I want to know how to go about transporting my code form the arduino to another micro-controller or something similar so I can have my project work on its own, without the arduino. It's basically 6 LEDs (possibly adding more) two tactile switches and some code, What do I do next? What do I buy?
frank26080115
just get a ATmega328P chip, and use a AVR programmer, you don't even need the crystal if you set the fuses to run it with the internal 8 MHz oscillator.
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
tbaldwin102
Could you explain a little more? I know what the atmega chip is but you lost me at crystal. If you can't tell I'm a bit of a noob:)
CrossRoads
#3
Jun 28, 2011, 07:18 am Last Edit: Jun 28, 2011, 07:26 am by CrossRoads Reason: 1
Or get the parts to make a standalone arduino - buy an atemega that has a bootloader on, and these parts from dipmicro: 16 mhzcrystal, two 22 pf Capacitors, three 100nf capacitors, a 10K resistor, a 28 pin socket, and some perfboard to build it up on.
And a 5V wallwart for power.
Program your new chip with your sketch using your arduinio, confirm it works, then plop it into your new board.
Wire it up like so with your parts going go to where I show connectors.
Should end up looking like the little green board here, with connectors as you need for your parts.
This one has I think a 10-pin connector - +5 in (from the PCB on the left), +5v out (to the PCB on the right), ground (from the PCB on the left), serial in (from the PCB on the left) and 3 output lines to each PCB.
tbaldwin102
So if I threw the new ATmega chip into the arduino and uploaded the program onto it, removed it and placed it in the new circuit it will have the program on there?
CrossRoads
tbaldwin102
Thanks for taking your time to help!  :)
CrossRoads
No problem.
Point to point wiring sucks too - other swear by it - I use wirewrap sockets &  header strips, solder them to the board and then connect everything via wirewrap. So much quicker to put together, or to correct mistakes, or to make changes later if needed.
The last of my promini's on a board, next build used a standalone uC like the previous post:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
