Topic: Code-Kontrolle (Read 876 times) previous topic - next topic
Logomaus
Hallo zusammen!
Habe hier mal ein ganzes Programm. Könnte es mir mal jemand durchchecken?
Vielleicht sind ja Fehler drin! Es soll die Webseite an den Client gesendet werden,
wenn es an der Tür klingelt.
Vielen Dank schonmal. Freue mich auf jede Hilfe!
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x40, 0xF2 };    // MAC-Adresse
byte ip[]  = { 192, 168, 178, 22 };                     // IP-Adresse
byte gateway[] = { 192, 168, 178, 1 };                  // Gateway
byte subnet[]  = { 255, 255, 255, 0 };                  // Subnetz
byte xbmc_ip[] = { 192, 168, 178, 43 };                 // XBMC IP
Server server(80);
Client xbmc(xbmc_ip, 80);
int Pin8 = 8;  // Digital Input
int Pin3 = 3;  // Digital Output
int Pin5 = 5;  // Analog Output
int Pin6 = 6;  // Analog Output
int state;
int helligkeit = 0;
String readString = String(100);      // String for data from address
boolean Pin8ON = false;               // Status flag
boolean Pin3ON = false;               // Status flag
boolean Pin5ON = false;               // Status flag
boolean Pin6ON = false;               // Status flag
    server.begin();
    pinMode(Pin8, INPUT);
    pinMode(Pin3, OUTPUT);
    pinMode(Pin5, OUTPUT);
    pinMode(Pin6, OUTPUT);
    digitalWrite(Pin3, state);
    analogWrite(Pin5, helligkeit);
    analogWrite(Pin6, helligkeit);
     //Create a client connection
    Client client = server.available();
    if (client) {
        while (client.connected()) {
            if (client.available()) {
                char c = client.read();
                //read char by char HTTP request
                if (readString.length() < 100) {
                    //store characters to String
                    readString = readString + c;
                //output chars to serial port
                Serial.print(c);
                //if HTTP request has ended
                if (c == '\n') {
                    // indexOf locates a character or String within another String
                    // returns the index of val within the String, or -1 if not found
                    if(readString.indexOf("3=einschalten") > -1) {
                        //Setting Pin3 to HIGH
                        digitalWrite(Pin3, HIGH);
                        //printing to line that door is open
                        Serial.println("Tür ist offen!");
                        //setting local variable to true
                        Pin3ON = true;
                        //sleeping for 2.5 seconds
                        delay(2500);
                        //setting Pin3 again to LOW
                        digitalWrite(Pin3, LOW);
                        //printing to line that door is now closed again
                        Serial.println("Tür ist geschlossen!");
                        //setting local variable to false again
                        Pin3ON = false;
                    if(readString.indexOf("5=heller") > -1) {
                        if(helligkeit<255) {
                            helligkeit++;
                            delay(10);
                            Serial.println("Dimmen +");
                            Pin5ON = true;
                    //else { Pin5ON = false;
                    if(readString.indexOf("6=dunkler") > -1){
                        if(helligkeit!=0) {
                        helligkeit--;
                        delay(10);
                        Serial.println("Dimmen-");
                        Pin6ON = true;
                    else {
                        Pin6ON = false;
                    if(readString.indexOf("all=Alles+aus") > -1){
                        analogWrite(Pin5, LOW);
                        analogWrite(Pin6, LOW);
                        Serial.println("Alles ausgeschaltet");
                        Pin3ON = false;
                        Pin5ON = false;
                        Pin6ON = false;
                    if(readString.indexOf("klingel=Klingel") > -1){  // (sphere start)
                        if (xbmc.connect())
                            Serial.println("xbmc connected");
                            // Make a HTTP request:
                            xbmc.println("GET /xbmcCmds/xbmcHttp?command=ExecBuiltIn(RunScript(special://home/addons/script.playcam/default.py)) HTTP/1.0");
                            Serial.println("xbmc command sent");
                            xbmc.stop();
                            // could not contact xbmc
                            Serial.println("xbmc connection failed");
                    }  // (...end)
uwefed
Im erst? Fragst Du das?
Grüße Uwe
Logomaus
Hi Uwe!
Wieso? Kann doch Fehler machen  :)
Oder wie meinst du das?  :D
Kannst du einen Fehler finden?  :D
uwefed
Daß Du es Dir etwas zu leicht machst. So wie Du schreibst finde ich mich auf den Arm genommen von Dir.
Funktioniert das Programm oder nicht?
Brauchst Du Hilfe weil es nicht funktioniert?
Was macht es genau?
Was sind die Eingänge/Ausgänge?
Grüße Uwe
Logomaus
Natürlich funktioniert es nicht, der Ausgang drei lässt sich so nicht schalten.
Bin nicht selbst am Programmtesten, gebe nur die Fehler weiter.
LG
sui
- Ein Client fordert etwas vom Server an und bekommt es erst und ausschließlich als direkte Antwort. Webseiten können also gar nicht ohne vorherige Anforderung vom Browser an den Server zurück zum Browser geschickt werden => Geht einfach nicht (siehe auch hier).
Um es nochmal mit einem schlechten Vergleich zu verdeutlichen: Wenn Du (=Client) nichts in einem Onlineshop (=Server) bestellst, bekommst Du auch kein Paket von denen geliefert, weil die weder wissen ob/was Du haben möchtest, noch wo Du wohnst.
- Im Code ist nichts was irgendwie irgendetwas mit dem Klingeln einer Tür zu tun haben könnte.
