Topic: To delay or not to delay - that is *not* the question! (Read 3428 times) previous topic - next topic
Msquare
Jun 29, 2011, 02:26 am Last Edit: Jul 04, 2011, 02:59 am by Msquare Reason: 1
Final proper version on http://arduino.cc/playground/Code/AvoidDelay  this was a draft
Introduction
Why not to use delay(), and how to get two "delays" run independent of each other.
We know:
1: The loop() runs endlessly and very fast.
2: digitalRead will look at the input at the time it is called only, likewise digitalWrite and output.
3. delay() will wait - it stops everything (except interrupts) while we count the milliseconds
Attempt 1: When button is pushed, turn a LED ON for 15 secs (15000 millis)
Code: [Select]
(Note: This is pseudo code, ignoring the syntax of "{" and so on, concentrating on
 the flow of the code. Also we are assuming a perfect button without contact bounce.
 As it happens, most examples here will work with a "noisy" button,
 as the LED timing hides the bounce.)
if digitalread==Down
 then digitalWrite ON , delay 15sec , digitalWrite OFF
Results: It works, yes, but looking closely:
The button can change up or down as much as you like in the 15 seconds - it simply is not looked at.
The delay starts counting when button is pushed. If the button is still down when 15 seconds expire, the LED will blink Off for a very short time (the time it takes loop to start again)
Attempt 2: The same with two buttons and two LEDs
Code: [Select]
if digitalreadA==Down
 then digitalWriteA ON , delay 15 sec , digitalWriteA OFF
if digitalreadB==Down
 then digitalWriteB ON , delay 15 sec , digitalWriteB OFF
Result: This does NOT WORK the way it usually is intended - whilst A or B is on, we are totally ignoring the other button. This is why delay() is fatal and very wrong if you need to do more than one and only one thing at a time.
Example 1: Implementing a simple timer
Code: [Select]
unsigned long Timer   ALWAYS use unsigned long for timers, not int
(variable declaration outside setup and loop, of course)
if digitalRead==Down
 then "set timer" Timer = millis , digitalWrite ON
if "timer expired" millis-Timer >= 15000UL
 then digitalWrite Off
(the "UL" after the number is a syntax detail that is important when
dealing with large numbers in millis and micros, therefore it
is shown although this is pseudo code)
Result: It works just as well as the delay version, but slightly differently:
The timer is constantly reset as long as the button is pushed. Thus only when releasing does it start "count" the 15 seconds. If you push shortly inside the 15 seconds period, it starts counting from anew. Notice in particular digitalRead is looking at the input as fast as loop() runs.
We are redundantly doing digitalWrite OFF,even when the LED is not lit for every loop() pass, and likewise digitalWrite ON as long as the button is pushed. This has no ill effects.
Example 2: as 1, but With two buttons and LEDs: Just "repeat" the above.
Code: [Select]
unsigned long TimerA    ALWAYS use unsigned long for timers.
unsigned long TimerB
if digitalReadA==Down
 then  TimerA= millis() , digitalWriteA ON
if millis()-TimerA >= 15000UL
 then digitalWriteA Off
if digitalReadB==Down
 then  TimerB= millis() , digitalWriteB ON
if millis()-TimerB >= 15000UL
 then digitalWriteB Off
Result: This works! Two seperate "timers start and stop independently.
As shown in the single button/LED case, we are done with handling the A case in just a few tens of microseconds, whether we are counting seconds or not, and thus free to handle the B case. We thus examine and react to either buttons hundreds of times each millisecond.
Interesting sideissue: The 4 if statements can be freely rearranged - the end effect is the same. (There are some subtle differences only active for the few microseconds until loop() goes round again.)
The effect that the timer is to start on button push or button release, or if a button should be ignored once the timer has started may be a requirement. Timer code can be made to handle all variations by storing the desired state and skipping digitalRead. This will work fine with two buttons, too.
Example 3: Timer with State change
Code: [Select]
boolean LEDon = false
if not LEDon and digitalRead==Down
  then "set timer" Timer= millis , digitalWrite ON , LEDon = true
if LEDon and millis-Timer >= 15000UL
  then digitalWrite Off , LEDon = false
Result: This will not do digitalRead or reset the timer, once the LED has turned on, ie we are starting the timer on button push (like attempt 1 earlier). Likewise it only tests the timer if the LED is on, and only turns it off once (which make very little difference, so I would normally omit the LEDon test in the 2nd part)
Example 4: One button, one LED - each with their own timer; A more usefull(?) example of doing two timing things "at once"
Code: [Select]
boolean buttondown = false
unsigned long LEDtimer = 0        ALWAYS use unsigned long. Not int.
unsigned long buttontimer = 0
if millis - buttontimer >= 5UL "debounce 5 millisec"
  and not buttondown and digitalReadButton==Down
        then buttondown = true , buttontimer = millis
  and buttondown and digitalReadButton==Up
        then buttondown = false , buttontimer = millis
if not LEDon and buttondown   "can use: not buttondown"
 then LEDtimer = millis , digitalWrite ON , ledon = true
if millis - LEDtimer >= 15000UL
Result: The button timer will purposfully skip digitalRead of the button for 5 millisec after it has changed. This filters away the "noise" in any mechanical button. The Led on/off code can be set to trigger on button down or up.
A challenge :)
If you use a previousbuttonup indicator instead of LEDon, you can ensure that the button has to be released before a new timer cycle can start - but that is left as an exercise, and is more about state transition than about timers.
So, this was the last time you used delay, right?  (there will be exceptions, of course)
retrolefty
Nice job. It's always better to be able to show someone rather then just telling them.
Quote
I live for the exceptions in life amoung the twilight spaces between right and wrong, left and right.  :D
Lefty
CrossRoads
Looks like a good discussion to replace the blink without delay example
Coding Badly
Quote
]:D
Quote
if millis - buttontimer > 5L "debounce 5 millisec"
I do believe you forgot something necessary to make the code match the comment.
jraskell
How about a good discussion to just eliminate the blink with delay example?
PaulS
Quote
Code: [Select]
// Hang on a minute
delay(60000UL);
jraskell
As long as I can do something else while I hang on...
retrolefty
The wisdom of using a delay or not really depends on how you want your sketch flow to work. A blocking delay may be properly what you want. Here is an example ( not using delay here, but certainly a blocking action) of where I want the program to do nothing until I send a character from the serial monitor, so that maybe I can prepare test equipment for a measurement I want to observe, etc. Even tongue in cheek saying that delay() should be banned seems pretty silly to me. Now getting the point across to newcomers to coding about the negative consequences of using the delay function is a whole other matter and worthy of further discussion.
Code: [Select]
  Wire.begin();
  Serial.begin(57600);
  Serial.println ("Hit a key to start");     // signal initalization done
  while(Serial.available() == 0){}           // wait for user to start
Msquare
Made some minor tweaks, mostly formatting (and a typo/missing word)  Codingbadly suggested >= instead of > to be accurate and UL instead of L.
I do NOT want to start a delay is evil mantra. (See discussion on goto is evil elswhere on how constructive that is). I just want to show that delay will break any concurrency programming the coder may want to do.
I have not explained that here are two "wraparound" problems with timers. (for the uninitiated that may read this: The first being a non-problem; using unsigned means the code works correct even if the millis wrap while we are timing. The other is a problem; the timers will "reset" if they have not been used for the duration of a whole millis cycle (approx 49 days)) The lack is intentional.
I am thinking of removing the "(except interrupts)" as I see no need for interrupts. They open so many new issues for the "beginner"-coder. I have made code that control DCmotors with simple encoders, thermostats, serial communication (both directions) all in ONE sketch using active polling (timed at <= 80uS for each loop) without timing hickups just by "a little care" in the code flow.
Any other constructive criticism (=unbridled praise  ;))?
Msquare
RoboDev
Hello;
After having gotten an Arduino just a few months ago, I am rather new to the system. After much investment of time (and money);
I decided to create a small test robot.  When it began to get more complicated, I ran into problems with delay() and reading my PING))) sensor.(I had a MaxSonar EZ1; but had a terrible experience with it)
Here is the second beta of my code...
Quote
#include <Servo.h>
Servo Direction;
Servo DriveR;
Servo DriveL;
const int forwardThreshold = 30;// 12  inches
int forwardDist;
int RightDist;
int LeftDist;
unsigned long sensorWait = 150, servoWait = 500;
  Serial.begin(9600); //for debugging
  DriveR.attach(9);
  DriveL.attach(11);
  Direction.attach(10);
//needs improvement.
  int sensor = AquireDist();
  DriveR.write(360);
  DriveL.write(-360);
  if(sensor < forwardThreshold)
    DriveR.detach();
    DriveL.detach();
    Direction.write(90);
    forwardDist = AquireDist();
    Serial.println(forwardDist); // for debugging
    if(millis()>= sensorWait);
    sensorWait = sensorWait + millis();
    Direction.write(0);
    if(millis()>= servoWait);
    servoWait = servoWait + millis();
    LeftDist = AquireDist();
    Serial.println(LeftDist);// for debugging
     sensorWait = sensorWait + millis()+150;
    Direction.write(200);
    delay(300);
    RightDist = AquireDist();
    Serial.println(RightDist);// for debugging
     sensorWait = sensorWait + millis()+300;
    servoWait = servoWait + millis()+ 150;
    DriveR.attach(9);
    DriveL.attach(11);
  if(RightDist> LeftDist && RightDist > forwardThreshold)
    DriveL.write(360);
    delay(1500);
    DriveR.write(360);
    delay(1500);
   if(sensor > forwardDist && sensor > forwardThreshold)
  {}// do nothing, go back to  beginning... goto is messy when used too often
int AquireDist() // this can be used with any digital in/out sonar type distance sensor (PWM).
  const  int sensor = 7;
  int duration;
  pinMode(sensor, INPUT);
  //ping…(wait for the pong)
  pinMode(sensor, OUTPUT);
  digitalWrite(sensor, LOW);
  delayMicroseconds(2);
  digitalWrite(sensor, HIGH);
  delayMicroseconds(5);
  //listening for pong now
  duration = pulseIn(sensor, HIGH);//PpPpPOoOoOnnnnnnng(hopefully)
  Serial.println(duration / 29 / 2 ); // for debugging
  return duration / 29 / 2 ;//convert to a human number with a unit...
RoboDev @ InfiniteSystems
Msquare
And the question is .... ?
Well, I can guess - although I prefer people ask.
Code: [Select]
if(millis()>= sensorWait);is not doing anything usefull at all. You have no conditional code between the ")" and the ";". Syntax here.
May I respectfully suggest that you post any further questions in a new topic, as this one is for discussing the instructional value of the long explanation.
AWOL
Code: [Select]
..just as long as it is attached to pin 7.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
