Seattle WA
Offline
Full Member
Arduino rocks
« on: June 29, 2011, 01:47:36 am » |
I've been working on a pin and software compatible Arduino variant for some time, the Zigduino. It is based around the ATmega128RFA1, which gives it a built-in 802.15.4 radio as well as a good deal more flash and RAM than a standard Arduino (128K and 16K, respectively). It is substantially more electrically rugged than a standard Arduino -- each pin can handle a +/-30V transient. It is now on sale at http://www.logos-electro.com/zigduino. My sales announcement on my company blog is at http://www.logos-electro.com/blog/2011/6/28/zigduinos-for-sale.html.
Logged
Seattle, WA
Offline
God Member
« Reply #1 on: June 29, 2011, 02:30:27 am » |
Nicely done! The ATmega128RFA1 is a firecracker. Nice to see it on a board. I think I am going to go after one of your prizes.
Logged
Dubuque, Iowa, USA
Offline
Edison Member
« Reply #2 on: June 29, 2011, 05:56:05 am » |
Have you tested the open air transmit range using the supplied antenna? I do not see any estimates in your product description or any of your documentation.
Logged
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #3 on: June 29, 2011, 09:44:54 am » |
Chagrin,
Achievable range is subject to a great variety of variables. Since I'm not equipped to do a range test to the applicable IEEE standards, I decided it was better to not make formal claims as to range rather than to make ones that I don't have full support for.
That said, you should see range equivalent to the base XBee module, which is about 300 ft outdoors, unobstructed. Your range may vary.
Logged
0
Offline
God Member
« Reply #4 on: June 29, 2011, 09:55:41 am » |
Aww I've been waiting for another ATmega128RFA1 product on the market but you've taken away a lot of the extra I/O pins (no second USART makes me sad), and didn't give me enough cost savings to justify the missing pins (I take that back... I kind of like it more now). Hopefully you can break-out more pins in another revision
« Last Edit: June 29, 2011, 09:03:13 pm by frank26080115 »
Logged
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #5 on: June 29, 2011, 11:15:20 pm » |
Frank, I think you are the third person today to ask for all of the pins to be broken out in the next major revision.  I'm considering it.
Logged
0
Offline
Full Member
www.rocketscream.com
« Reply #6 on: June 30, 2011, 03:07:54 am » |
You might want install a light box on your website.  People will want to see the board image larger.
Logged
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #7 on: June 30, 2011, 08:42:09 am » |
I'll do that, now that I have images worth seeing bigger.
Logged
SF Bay Area
Offline
Full Member
Arduino rocks
« Reply #8 on: June 30, 2011, 05:24:49 pm » |
What's the throughput of the zigbee on that unit?
It must be obvious to some, but I don't know much about zigbee yet.
Logged
0
Offline
God Member
« Reply #9 on: June 30, 2011, 08:47:55 pm » |
rocketgeek
Although it's great that you've made all the pins 5V compatible, I have found myself almost exclusively using 3.3V components now-a-days. If the cost of making more pins 5V compatible is prohibitive, know that at least I myself would not care if you took away 5V compatibility.
It's 2011, 5V logic is dying
Other microcontrollers with built-in 2.4 GHz RF are not as beefy as the ATmega128RFA1, so taking away pins would be taking away one of the only things that makes the ATmega128RFA1 unique
Logged
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #10 on: July 01, 2011, 07:25:08 pm » |
Dying != dead; most of the shields currently for sale listed on shieldlist.org are 5V. I'm looking into ways to pull the other two ports out for the next revision.
Logged
0
Offline
God Member
« Reply #11 on: July 02, 2011, 03:00:12 pm » |
it'll be great if you can come up with a open source MAC, is there any plans for that?
Logged
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #12 on: July 02, 2011, 09:14:48 pm » |
Frank, I'm talking to the uracoli guys about porting that over, and offering free hardware for porting uracoli and contiki. Dropping a line to the uracoli project might make it happen faster.
Logged
0
Offline
God Member
« Reply #13 on: July 02, 2011, 10:09:17 pm » |
That's good news.
There's a good chance that Atmel simply threw the silicon from the standalone transceivers into the MCU, eliminating the need for a SPI interface, meaning porting over existing code should be as easy as replacing some SPI functions. Hopefully this is the case.
Logged
Seattle WA
Offline
Full Member
Arduino rocks
« Reply #14 on: July 02, 2011, 10:34:56 pm » |
There's a high probability that they did exactly that. I'm told that's a very common approach for companies making their first SoC products. Inspection of the PAL/TAL/TFA modules in the Atmel MAC also tends to support that assumption.
Logged
