Topic: 2 passwords (maybe more) (Read 860 times) previous topic - next topic
rajael
Is there a way in the password library that can define 2 passwords? For example, one user will use '1234' as his password and the other user will use 'ABCD'.  This way I can monitor who goes in a certain room. TYVM.
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
rajael
Ok, can you show me how?
I tried the following lines
Password pass1 = Password("1234");
Password pass2 = Password("ABCD");
and in checking, the ff lines
if(pass1.evaluate(){
//do this
if(pass2.evaluate(){
//do that
else{
//do nothing
Pressing the 1234 works. pressing ABCD goes to do nothing. TYVM.
Cylindric
I've not used that library, but have you tried (re)setting the password in the setup?
Code: [Select]
Password pass1 = Password();
Password pass2 = Password();
  pass1.set("ABCD");
  pass2.set("1234");
  //whatever
PaulS
Quote
None of my Arduinos have anything called a 1234 or an ABCD to be pressed. You need to show all of your code, so we have some idea what "pressing the 1234" and "pressing ABCD" mean.
rajael
I finally got it right...
Here's the code as requested.
#include <Password.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
Password pass1 = Password("ABCD");
Password pass2 = Password("1234");
int spkrpin = 9;
int ledpin = 13; //will be use for activating a relay
int ctr = 0; //LCD column counter
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {46, 48, 50, 52}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {47, 49, 51, 53}; //connect to the column pinouts of the keypad
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //connect to the LCD pinouts
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  pinMode(spkrpin, OUTPUT);
  pinMode(ledpin, OUTPUT);
  digitalWrite(ledpin, LOW);
  lcd.begin(16,2);
  keypad.addEventListener(keypadEvent);
  keypad.setDebounceTime(250);
void loop(){
  keypad.getKey();
  lcd.setCursor(0,0);
  lcd.print("Type password...");
void keypadEvent(KeypadEvent eKey){
   switch (keypad.getState()){
     case PRESSED:
   lcd.setCursor(ctr++,1);
        lcd.print(eKey);
   digitalWrite(spkrpin, HIGH);//Makes a clicking
        delayMicroseconds(500);     //sound after pressing
        digitalWrite(spkrpin, LOW); //a key
        switch (eKey){
          case '#': guessPassword(); break;
          default: {
            pass1.append(eKey);
            pass2.append(eKey);
void guessPassword(){
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("Checking ...");
     if (pass1.evaluate()){
        lcd.setCursor(0,1);  lcd.print("PASSWORD OK");
             digitalWrite(ledpin,HIGH);
             delay(2000);
             digitalWrite(ledpin,LOW);
             pass1.reset();
             pass2.reset();
     else if (pass2.evaluate()){
             delay(2000);
             pass2.reset();
             pass1.reset();
     else{
             lcd.setCursor(0,1);  lcd.print("WRONG PASSWORD");
        pass1.reset();
             pass2.reset();
     ctr=0;
     delay(3000);
     lcd.clear();
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
