Topic: CRT Test Patterns? (Read 2087 times) previous topic - next topic
Scucci
I'm wondering if there is anyway to use an Uno to generate a few simple test patterns for arcade machine monitors? I'm really only interested in the "standard" resolution monitors as the machines I have and are interested in use that monitor.
I did a quick search and nothing came up so I figured I'd ask.
As a note, most monitors have separate pins for the red, green, and blue signals. As well as separate pins for GND and your a h-sync and v-sync, 2 sets of pins actually for positive h/v sync, or negative h/v sync (some games use positive, some negative).
There are basic patterns I'm looking to make. One is a basic grid of white lines. Then some screens of solid red, solid green, solid blue, and solid white. Then a screen with 4 squares lined up horizontally(sides touching), 1 red, 1 blue, 1 green, and 1 white.
It seems doable as I have access to each individual pin for each color, and I'd imagine the 328 should be powerful enough to handles something like that, right?
Problem is, I'm fairly uncertain about how to set something like that up... if at all possible.
So, those are my questions I guess... Can the Arduino do it? What the highest resolution it could handle (would probably have to use switches to tell the board what resolution monitor I'm hooked up to)? And if so, how would I go about starting on it? (newbie)
                  STANDARD RESOLUTION
          HORIZONTAL                    VERTICAL
Scan Frequency: 15.72 KHz    Scan Frequency: 60.0 Hz
   Scan Period: 63.6 µSec       Scan Period: 16.7 mSec
  Active Video: 46.9 µSec      Active Video: 15.3 mSec
   Video Delay: 11.9 µSec       Video Delay:  1.2 mSec
    Sync Pulse:  4.7 µSec        Sync Pulse:  0.2 mSec
     Scan Line: 456 Pixels           Screen: 262 Lines
    Resolution: 336 Pixels       Resolution: 240 Lines
    Clock Freq: 7.16 MHz
                   EXTENDED RESOLUTION
          HORIZONTAL                    VERTICAL
Scan Frequency: 16.50 KHz    Scan Frequency: 53.0 Hz
   Scan Period: 60.6 µSec       Scan Period: 18.9 mSec
  Active Video: 48.0 µSec      Active Video: 17.4 mSec
    Sync Pulse:  3.9 µSec        Sync Pulse:  0.2 mSec
     Scan Line: 646 Pixels           Screen: 312 Lines
    Resolution: 512 Pixels       Resolution: 288 Lines
    Clock Freq: 10.67 MHz
                    MEDIUM RESOLUTION
          HORIZONTAL                    VERTICAL
Scan Frequency: 25.00 KHz    Scan Frequency: 60.0 Hz
   Scan Period: 40.0 µSec       Scan Period: 16.7 mSec
  Active Video: 32.0 µSec      Active Video: 15.4 mSec
   Video Delay:  7.2 µSec       Video Delay:  1.2 mSec
    Sync Pulse:  4.0 µSec        Sync Pulse:  0.2 mSec
     Scan Line: 640 Pixels           Screen: 416 Lines
    Resolution: 512 Pixels       Resolution: 384 Lines
    Clock Freq: 16.00 MHz
                     VGA20 RESOLUTION
          HORIZONTAL                    VERTICAL
Scan Frequency: 31.55 KHz    Scan Frequency: 70.0 Hz
   Scan Period: 31.7 µSec       Scan Period: 14.3 mSec
  Active Video: 25.6 µSec      Active Video: 12.2 mSec
   Video Delay:  5.7 µSec       Video Delay:  1.1 mSec
     Scan Line: 634 Pixels           Screen: 450 Lines
    Clock Freq: 20.00 MHz
midmofarmer
check out the tv out libraby can't seem to find it right now and maybe drive it from an old set, but beware of the voltage as i'm shure your aware, the sync shouldn't be that hard to adjust as it might over run but you should be able to get a good test been a while for me
Scucci
The TVOut library gives a composite signal for sync and colors. I can get by with composite sync by tying them together on the monitor's chassis. Most monitors shouldn't have a problem with that as some arcade boards put out composite sync. But I can't do much of anything with composite colors.
The TVOut library is like that, I believe, because on 99.9% of monitors/tvs you have to use the RCA jacks to send in a video signal. Sadly, the monitors I work on are that in 0.1% where the only access to the colors/sync you have is at board level..
Thanks for the heads up on the voltage, but I've already been bit by the flyback a few times. It's to the point now where line (110'shV here) just feels like a tingle. ;P
Scucci
Got around to hooking the TVout demo up to an arcade monitor, runs just fine (sync wise).
I guess the big issue is getting the separate red, green, and blue signals from separate pins... with white just being all of them at once.
http://www.youtube.com/watch?v=xLzKrMnbR-s
Scucci
After tinkering, it looks like it'd be something along the lines of setting VID_PIN in "hardware_setup.h" to a different pin on the fly... doable?
