Loading...
Pages: [1]   Go Down
Author Topic: error with "if" statment  (Read 326 times)
Offline Offline
Newbie
View Profile
Sorry for the newbish question here, but I am new to C programming, as well as the arduino.
So, I am working on trying to get the Night Rider effect with 8 LEDs (dig outs 2-9). I want to control the speed with a POT. Now, I was able to do so, with calling each LED in sequence (2,3,4,5,6,7,8,9,8,7,6,5,4,3 loop). SO, I started trying to clean up the code a bit with a couple nested if statements.
Code:
int sensorPin = A0;
int ledPin = 2;
int sensorValue = 0;
int reverse = 0;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  if   (reverse = 0); { // count up
       digitalWrite(ledPin, HIGH);
      sensorValue = analogRead(sensorPin);
      delay(sensorValue);
      digitalWrite(ledPin, LOW);
      delay(sensorValue);
          if (ledPin = 9) {
            reverse = 1;  }
          else ledPin = (ledPin + 1);
[u][b] else // count down[/b][/u]
      delay(sensorValue);
      delay(sensorValue);
          if (ledPin = 2) {
            reverse = 0;  }
          else ledPin = (ledPin - 1);
However, I am getting
Quote
sketch_jun30b.cpp: In function 'void loop()':
sketch_jun30b:29: error: 'else' without a previous 'if'
with the bolded underlined portion of code being pointed out.  Why isn't that "else" associated with the very 1st "if"?
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Code:
      delay(sensorValue);
      delay(sensorValue);
          if (ledPin = 2) {
            reverse = 0;  }
The else is only coupled with digitalWrite(ledPin,HIGH);
Thought you may want to know that. Your first if structure indicates everything after the else should be inside {} but you didn't put them  in.
Plus, all if statements are wrong, at least not giving you what you want, use "==" instead of "=" if you compare values like if (ledPin==2) not if (ledPin=2).
Fix the above possible mistake and see if you get what you want.
Logged
Mountain View, CA
Offline Offline
Newbie
Professional C/C++ programmer available for projects
View Profile
WWW
Remove the semicolon after the "if" condition.
Code:
Logged
Offline Offline
Newbie
View Profile
Cool.. I'll give that a go and check it out. Thank you.. I'll update success of failure  smiley
Logged
Offline Offline
Newbie
View Profile
Well, removing the ";" fixed the missing if error, and I changed to the double "=", but it wont move past pin 2. My "count up" is failing.. back to the drawing board.
Logged
Mountain View, CA
Offline Offline
Newbie
View Profile
WWW
Can you post your code properly formatted ??  Get rid of the annotations in brackets and write the "if/else" conditions in a neater style such as this:
Code:
if (cond) {
  doSomething();
  doSomethingElse();
I have a hard time parsing your code and understanding what it is trying to do.
« Last Edit: June 30, 2011, 10:01:42 pm by montecito » Logged
Offline Offline
Newbie
View Profile
Okay.
Code:
int sensorPin = A0;
int ledPin = 2;
int reverse = 0;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  if   (reverse = 0) { // count up
      delay(sensorValue);
      delay(sensorValue);
          if (ledPin = 9) {
            reverse = 1;
            ledPin = (ledPin+1);
  } else { // count down
      delay(sensorValue);
      delay(sensorValue);
          if (ledPin = 2) {
            reverse = 0;
            ledPin = (ledPin-1);
Logged
Mountain View, CA
Offline Offline
Newbie
View Profile
WWW
This is a problem:
Code:
          if (ledPin = 2) {
Replace with
Code:
          if (ledPin == 2) {
I don't know if that will fix everything but it's an obvious problem.
Logged
Offline Offline
Newbie
View Profile
Yeah, I reverted back trying to debug. As soon as I changed it back to "==", all is working as desired. Thank you all for your help  smiley
Logged
Mountain View, CA
Offline Offline
Newbie
View Profile
WWW
This too:
Code:
          if (ledPin = 9) {
Comparisons are == not = as the other poster pointed out.  Check all our "if" statements for this error.
Logged
Central MN, USA
Offline Offline
Faraday Member
View Profile
WWW
There is no reason to revert. The single equal is value assignment, double is comparison. I suggest you learn the operators && and ++. Your code may work but is very bloated without proper use of them.
Logged
Fresno, CA, USA
Offline Offline
Full Member
Arduino rocks (literally, with a WaveShield!)
View Profile
WWW
A little explanation of "=" vs "==" is in order...
"=" means "assign", as in "a=2" -> "set a to 2". This compiles properly, because "a=2" also passes-through the value "2", so things like "a = b = c = d = 2" are possible, setting a, b, c, and d to "2" by referencing each other.
"==" means "check if equal". It returns "1" if they are the same, and "0" if they aren't the same. Basically.
So if you want to check if two things are the same, use "==". And if you want to "assign and check" - like, "if (x = buttonCheck())", which would mean that "x" is set to the value returned by buttonCheck() and the loop would run if the value is non-zero (e.g. the function returns 0 if nothing is pressed, otherwise it returns the button that was pressed), but not have to run buttonCheck() a second time.
Logged
Pages: [1]   Go Up
Print
Jump to:
