Loading...
Pages: [1]   Go Down
Author Topic: 328P clock frequency and supply voltage  (Read 624 times)
Grand Blanc, MI, USA
Offline Offline
Faraday Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
Maybe this is obvious, or implied via convention, I spent a fair amount of time in the datasheet and didn't see anything explicit.
The attached figure does refer to system clock frequency only, and not to oscillator frequency?  For example, I could use a 16MHz crystal, set the system clock prescaler to divide by four, and operate safely down to 1.8V?  Or use the internal 8MHz RC oscillator, divide by two, and operate safely down to 1.8V?
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I believe the answer to all three questions is "yes".  I vaguely recall other parts of the datasheet hint that what you want to do is within the specifications.
It looks like there are enough hints in section 8 for a "yes" answer.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
The prescaler itself is hardware based and has to deal with the input frequency with the Vcc it is given. Deviate from the clock speed Vs Vcc voltage at your own risk.  smiley-wink
Lefty
Logged
Offline Offline
Faraday Member
View Profile
WWW
@coding, thanks, that's what I was guessing, but was feeling more OCD than usual today.
I just saw the notes similar to this in each section describing the various oscillators, so I think that's a pretty strong "Yes".  @lefty, you disagree, though?
Quote
If the crystal frequency exceeds the specification of the device (depends on VCC), the CKDIV8
Fuse can be programmed in order to divide the internal frequency by 8. It must be ensured
that the resulting divided clock meets the frequency specification of the device.
« Last Edit: July 01, 2011, 12:18:31 pm by Jack Christensen » Logged
Offline Offline
Newbie
View Profile
Quote
Although it is slightly out of spec one can comfortably run the atmega328p at 3.3v at 16mhz. Thus avoiding the use of troublesome level shifter ic's etc if one wants to interface the atmega with a 3.3v ic.  According to that graph the recommended frequencyfor 3.3v is around 12 mhz but all chips run comfortably at the default 16mhz at 3.3v even.
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
Yup, I've run all three of mine at 3.3v and 16mhz, no issues yet.
Logged
Offline Offline
Brattain Member
View Profile
Quote
Not at all. Just as long as one is aware that they are exceeding AVR's specifications. It's not like the board is going to catch fire or anything. There are even commerical arduino clones that run @3.3v &16mhz, the Seeeduino board for one has a 5v/3.3v voltage selector switch on board running at the same 16mhz clock. What one is doing is running in a 'overclock' mode, a well known hobby in the Intel PC world.
Lefty
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Because 3.3V 16MHz is off the recommended range expect it to be unreliable at high temperatures (MOS goes slower at higher temps).
The clock prescaler circuit is unlikely to be a bottleneck, the process used is plenty fast enough I think.  Its the complex instruction execution where lots of stuff has to settle in one clock phase that will set the minimum clock period. Read up on modern VLSI design issues to do with clocking if you've months to spare to get a better insight - the clock period is usually many many gate delays.
Logged
Humboldt, CA
Offline Offline
Full Member
Arduino BBB
View Profile
Actually that reminds me, at 3.3v and 16mhz one of mine tended to crash (freeze, really) below 32*c.  I haven't tried at 5v though, so it's not proven that it's a voltage issue.  Just something to check.
Logged
Pages: [1]   Go Up
Print
Jump to:
